Mazda 6 TS2 2.2 diesel
Sep 13, 2010
65
Hi all
I have a Mazda 6 2.2 diesel and we are looking to change our caravan to a bigger one where the MTPLM will be 100% of the kerbweight of the car.
Where i am a confident tower, i am concerned about the ability of the car.
Does anyone else have a Mazda 6 and what do you tow with it? How does i cope
Jul 21, 2010
20
Craigstaiano,
What are the wieghts of your car and caravan - I've just had a look and there is a chance your outfit may be illegal depending on the type of Mazda 6 you have,
Cheers,
Rory - Reporter, Practical Caravan
Sep 13, 2010
65
The car is 1555, the van we are looking at has MTPLM of 1560. MIRO is 1315. There are only 2 of us so doubt we would use full payload
Jul 21, 2010
20
Ok that's fine, its just some Mazda 6 2.2 litre models have maximum towing limit of 1400kg, meaning your new 1560kg caravan would be an illegal match - unfortunately you have to go by the maximum weights and can't deduct payloads etc.
However, your 1555kg kerbweight model should have a maximum towing limit of 1600kg, which is legal.
Obviously we normally say tow a caravan with an MTPLM that is 85% of your towcar, but if you are experienced and confident towing a higher percentage it isn't illegal and I hope you enjoy your travels!
Rory
Sep 13, 2010
65
Rory
Many thanks for your reply. When i ordered the car i checked the tow weight out carefully as i wanted it to be able to tow more than the Golf i had previous.
Your reply is greatly appreciated
Craig
Jun 22, 2012
95
I have a Mazda 6-163ps 2.2 Diesel and tow a Luna Clubman 470-2 the power of the car is very good and i have no problems towing. The only thing i have found is that the rear suspension is very soft so i fitted a pair of grayson spring assisters to stiffen it up a bit, the ride is a bit harder when not towing but it's a lot more stable with the van on tow.
Jun 22, 2012
95
Sept 2009, if you want to get the assisters they cost me about £38-00 from Grayston about 3 month's ago they are available from most caravan dealers or Halfords but you will find most do not stock them as they are a larger size than standard.
Grayston do sell direct you can contact them on 0208 9741122 and they will send them next day delivery.
3,937
Two things that have arisen from this thread,
Rory White stated
“Ok that's fine, its just some Mazda 6 2.2 litre models have maximum towing limit of 1400kg, meaning your new 1560kg caravan would be an illegal match - unfortunately you have to go by the maximum weights and can't deduct payloads etc.”
Not quite true – It is perfectly legal for a car to tow any trailer provided the actual weight of the trailer (not the MTPLM) is within the tow vehicles limit.
So for example a car transport trailer may have an MTPLM of 2500Kg, but its MIRO is only 500Kg. It is perfectly legal to tow the trailer behind a car with 1000Kg towing limit when empty or part loaded so long as its actual weight does not exceed 1000Kg.
Drivers licence restrictions may make driving such a combination illegal.
Mucky pup added
“The only thing i have found is that the rear suspension is very soft so i fitted a pair of grayson spring assisters to stiffen it up a bit, the ride is a bit harder when not towing but it's a lot more stable with the van on tow.”
It is important to understand the car manufacture designs their car to handle all the loads within its specifications including the trailer masses and its nose load, so spring assistance is never necessary. If an outfit is found to be ‘bottoming’ or not able to handle the nose weight of the caravan/trailer, then the cause needs to be investigated.
It will come down to one or a combination of three things:-
1. The trailer is over loaded or incorrectly trimmed producing an excessive nose load.
2. the cars suspension is worn or broken,
3. the outfit is being driven in an inappropriate manner or over terrain outside the vehicles specification
None OEM or after market spring assisters are never necessary, and should not be used to correct a fundamental fault with the car, trailer or driver. They do not increase any load capacities. They modify the cars characteristics and only serve to satisfy a cosmetic aspiration. If they are fitted as a none standard item they should be reported to you vehicle insures as a modification.
