mercedes v class desiel
Oct 19, 2005
27
has anyone towed with a v-class/vito automatic desiel before.i have been offered a good deal on one ,it air suspension on the back.i tow a bailey sennator and the outfit match comes out as a good match-but you cant beat first hand experianc
thanks
Dec 16, 2003
2,893
Yep, have driven 10 of thousands of miles in V class's and now Viano.
Diesel output on the CDI is awesome for 2.2. I have a Bailey Sennator 5000 and it towed that brilliantly as it did the previous Bessacarr. ZF auto gear box is semi intelligent and changes depending on how you drive. If you have a heavy right foot it holds the revs before changing up and if you have a feather foot it takes its time. Also has winter mode and traction control and abs as standard, so pulling away with front wheel drive is easy all though new rear drive Viano is better. Air suspension keeps the car level and is great with the van behind. Sennator sat dead level with Bosal detachable tow hitch.
Beware of costly mercedes factory tow bar, and if it has reversing sensors you couldhave a problem getting right tow hitch. All Tow near Sonning Common Reading were good buys for
Bosal compared to Brink and have been fine.
CDI engine has lots of covers over the main engine, they do not remove covers during servicing and injectors tend to leak if not tightened down regularly. First sign of leaking injector is a hard to detect wisp of smoke from the side of the bonnet as fuel weeps and burns forming carbon mess between the Cams around the injectors. Don't believe dealer if tell they are not a problem, Mine and three others were sat in a garage all with a mass off carbon sat cooked on top of the engine! Happens on loads of Vito's as they are the same of course.
You need to invest in star type sockets to remove covers and air ducting and make sure area around injectors is clean and that bolt that holds the securing "fork" is in place and correctly torqued down. If the vehicle has done over 50k do not trust to servicing as until the computer shows a problem the dealer will not go looking! New injectors are about
Oct 19, 2005
27
Dec 16, 2003
2,893
Gary, make sure that the injectors are uncovered and phsyically inspected. Injectors should last life of car and make sure that they take glow plugs out as they can sieze on threads. Computer diagnostic does not show that injectors have slightly lifted weeping diesel that cooks on the cylinder head. I had it happen the day it had been serviced, diagnostic was fine I just noticed whisps of smoke as I drove from Merc dealers when engine was upto full temp.
Hope you enjoy the beast!
Oct 19, 2005
27
when the dealer does an injector test they have to take the covers off and fit small glass tubes to measure the amount of feul they are trying to return back to the tank
