Motor Mover for Twin Axle Elddis Crusader Storm
Nov 2, 2008
69
Hello, I am looking to buy a motor mover for my caravan and wondered if anyone could recommend a good one as my caravan is heavy and I have a tight turn into my drive. Thank You. Niki
Nov 5, 2005
115
Niki. I have a Reich 4 wheel drive mover It is very good soft start can move in tight spot no problem I have had my one for 3 years never had a problem with it
William
Apr 25, 2005
33
I too have a Crusader Storm and have a Powrtouch All Wheel drive.Works a treat.However, you will lose the spare wheel carrier although this can be replaced with an Alko carrier with a kit supplied by Powrtouch. Personally I decided to simply carry the spare in the van whilst towing.
Mar 15, 2008
119
I have very similar sized van Elddis Crusader Sirroco and had a Reich 4 wheel mover fitted by the Elddis dealer (they recommended Reich). We had to do this as we have a tight turn into drive and the road can get quite busy. So I find it easier to don hi vis-vest and stop traffic whilst "driving" van onto drive. Never had any problems with mover although the turning angle is never acute like you can get with a single axle.
Nov 2, 2008
69
Thank you for your advice. I have been told this morning by a caravan dealer that I could have a powrtouch 4 fitted to my caravan. My caravan when laden is 1900kg. I have a very slight slope on my drive. Its the turn that is tight and worries me. He says that I can upgrade later if I feel there isnt enough power. Does this sound right? Is the powrtouch powerful enough for my caravan weight? Thank you your comments they are very much appreciated. Niki
Feb 19, 2006
158
Dont bother unless it is 4 wheel drive on a twin, the 2 wheel drives wont turn corners and the motors will burn out after a while. I got a 4 wheel drive direct from powertouch for
4,359
Hello Niki,
You have a quite specific reason for wanting/needing a mover. this actually places you in a strong position as you must tell any potential supplier the detail of the job the mover must be able to do.
This is a very clear criteria, and the supplier must ensure that any product they recommend must be able to manoeuvre your caravan in the space and circumstances you have.
If you choose one of the recommended models, and have it fitted in accordance with the instructions, then you should be fine, But if for any reason the mover fails to meet the criteria you set, the dealer is responsible under the sale of goods act for not supplying goods fit for the specified purpose.
In reality, no one on this forum can make a certain recommendation as we cannot see the particular location and its difficulties. It makes more sense to go to the dealers and invite them to make recommendations.
5,395
I have the Powrtouch 4 or what is is now called the Powrtouch Twin on my Wyoming. Two motors not four.It does the job but being a twin does not turn as freely as a single axle.
However do think very carefully why you need a four motor drive.
You will have increased weight eating into your MTPLM.
You will have to resite your spare wheel carrier or lose it all together. Think about the revised weight distribution.
You will lose the Al-Ko jacking points. You will have to find an alternative method. Remember you cannot just jackup any old where on the chassis. This could caause you difficulties attaching your wheel locks etc.
Cheers
Alan
Nov 2, 2008
69
Hi Alan, Can I ask how heavy your caravan is? Mine is 1900kg laden. I really only want it to make life easier when taking in and out of my drive. Thanks Niki
5,395
Hi Niki
I have a Senator Wyoming, just under 1700kgs. We mainly use the mover when we want to face in at a pitch eg a cliff top view etc; or just some final adjustments where space is tight.
If your drive is flat I don't think you will have a problem.
Have you discussed your requirements with Powtouch? They have a very good cust omer helpline.
Cheers
Alan
Jan 22, 2009
8
Hi Niki we want a motormover for are twin axle caravan and maybe going to the show in Glasgow so we maybe able to get a good deal on two ?
Bob
Feb 15, 2006
71
Hi Niki
I have a powrtouch (not the 4wd) fitted to my 2008 Buccaneer Caravel T/A MTPLM 1900KG & it works a treat. We only use it though to get the caravan down our slight incline drive into back garden & occasionally on sites if its a bit tight to manouvre with car.
Not done any real turning so cant really comment as to if the 2wd is up to that compared with awd one.
But we are really pleased with its ability & ease of operation for our use
Nov 2, 2008
69
Hi Simon B
Thanks for your reply.
Can I ask how you managed to get such a great discount. I mentioned to powrtouch how much a member paid for there motormover on a forum and ask if they could match this but they weren't interested.
Feb 19, 2006
158
Hi
We managed to get a deal on our previous motor mover when they were offering to beat any other deal by
