Motor Mover Remote
Mar 20, 2011
96
10
18,585
Hi we have a Truma SE Motormover which was already fitted on the van when we purchased it. Other then an initial try to see if working when delivered as on a seasonal pitch we have not used and unfortunately we had left the batteries in the remote compartment which has now caused corrosion. Does any one know if the remote can be repaired or if we have to order a replacement handset how do you pair up with the mover on van. Any advice would be welcome! Thanks Annie
Mar 20, 2011
96
10
18,585
5,054
All the above , plus once fully cleaned spray all the electronics, pcb and battery terminals with Electrical Contact Spray.
Let it thoroughly dry, even leaving it in the airing cupboard overnight!
Apr 23, 2024
349
278
935
Please don't use emery cloth/paper/board , it will remove the electroplating on the battery contacts and the underlying base metal will rust again and you will be back to square one. If you do accidentally remove the electroplating a 'nickel' pen can can apply a film of nickel to the contact surfaces available from cpc farnell - part number SA 02343 , several coats are required.
I'd go with the repair guy Jcloughie posted about , also A & R electronics developments are pretty good and will probably replace the contacts with new.( I also keep a stock of battery contacts extracted from various electronic battery powered modules over the years for just such an eventuality).
Reactions: Annie3
5,054
We don’t know how bad the corrosion is .Leaking dry cell batteries give off a very corrosive alkaline residue , potassium hydroxide. I suspect any “plating” has been compromised.
So Annie needs to make the best of a bad job. Removal and cleaning up of the corrosion is very important.
Maybe the damage is already done and Mr Plodd’s suggestion will at least salvage the situation in part?
If it was mine I’d clean up and use the contact spray which as you know etches the surface. If the contacts thereafter are carefully cleaned regularly they should last a long time.
My own remote has suffered the same over the years and at 17 they are still going!
Reactions: Annie3
Mar 20, 2011
96
10
18,585
Thank you! Annie
Try A&R Electronics for repair or you may be able to find a used one on EBay and then pair it to your control box If you do buy second hand make sure you get the correct one as there are two types. One for manual operation and other for automatic has they have different buttons, Link here. https://www.arelectronics.co.uk/
Thank you ! Annie
Mar 20, 2011
96
10
18,585
Thankyou Annie
Thankyou Annie
Annie, a picture speaks volumes.
Thankyou I’ll try and work out how l add one to the post Annie
Oct 21, 2020
365
210
4,935
Order a fine brass brush from Amazon etc, they type used for suede shoes, give it all a brush and a dab of contact grease such as contralube.
Reactions: Annie3
