Motorised Jockey Wheel Fitment
Oct 8, 2016
16
:cheer: As a long term caravanner,and have been for 15 years plus,my current unit is a 1994 Isuzu Trooper 3.1 Turbo Diesel SWB with a Swift Challenger 1992 490/5 SE
I have recently purchased a Motorised Jockey Wheel to assist in getting the van up my drive as has a slight slope so Rear of van will bottom out if Reveresd by vehicle.
The problem I found with the mover is that if you have an "Inboard" mounted jockey wheel you have to remove the "A" Frame cover first.So undeterred I contacted the mover manufacturer to see if a kit was available to fit to front of "A" Frame and connect to the tow hitch via 50mm ball,I was informed that this kit is no longer manufactured.After hearing this I decided to get my tape measure out and drew up a workable plan and design for a bracket.
Still determined to make this work,I checked around to see if I had any scrap metal,after finding 2 old 18inch mower blades,and some angle iron,I decided to get the Angle Grinder and MIG Welder out.
After 3 days of cutting and grinding I have finally made the bracket I need to fit the mover to the Tow hitch,the bracket made can be removed after use,just leaving a support bracket fitted to the underside of the "A" Frame,thereby allowing the caravan to be towed as normal and not leaving the mover attached.
If any other members are using these movers,namely "Bigfoot" and "Euro-move" and have the same problem I would be interested to hear as I may be able to help,the bracket manufactured will fit any 48mm Jockey Wheel,as I know these movers require a 48mm Clamp.
You can contact me via email,please ask moderator for my email address and I will reply,
Many thanks.
936
First of all I must say that hitch mounted movers are a potential death trap.
They are really only suitable for perfectly level, smooth ground such as concrete or tarmac.
On soft surfaces they are useless and on inclines, dangerous.
However, you have made your choice.
I must ask, you mention a bracket fitted to the underside of the A frame.
Is this bracket welded to the A frame or bolted?
3,993
Sounds like you and "Sproket" should get together , we could get some great caravan items sorted. :)
Aug 23, 2009
3,167
I'm sorry to say, and it's only my opinion, that you would be much safer on an incline to ditch what you are using and get a motor mover.
Oct 8, 2016
16
The bracket fitted to the underside of the "A" rame is bolted using the 2 existing bolts at the front of the Tow hitch.
Oct 8, 2016
16
Thanks for your opinion,as it is only a short incline,and the age of the van it wouldn't warrant the expense of a motor mover,the jjockey wheel is adequate for the job at the moment.
199
19,235
Back in the '90s I bought a Mister Shifta to move my van from its parking spot and on to the drive. It was basically a pair of wheels which were motor driven and powered from an on board battery with a tow ball which fitted into the caravan coupling. At first I was greatly impressed with it but gradually I began to discover its shortcomings.. To move the caravan backwards or forwards in a straight line, it was fine. Try to turn the mover too quickly and it wanted to fall over. If I happened to get the mover on the lawn or onto gravel, the wheels would spin. Turns could only be done where there was lots of room. And it was too heavy to take with me. In 2000 I bought my first Powrtouch. What a difference. I haven't been without one since.
Sep 5, 2016
239
Same here a waste of money but they weighed a tonne, :)
4,765
The draw back with these kind of devices is no brakes.
A Powrtouch or similar stops the caravan dead. Well done for your innovation but not for me.
199
19,235
A Powrtouch or similar stops the caravan dead. .
The Mister Shifta gave you control. It has lever rather like a dead man's hand. Release it and the machine stops - dead. It also had soft-start. It wasn't all rubbish.
Oct 8, 2016
16
The only draw back I found when looking for a temporary mover was that the Mister Shifta was just to heavy for my needs,my current 1,the Euro-Move is ideal as I can remove it when not being used,and if required put in back of 4x4 and take it with me.
As with all things Mechanical,they are only as safe as the person using them,and if user instructions are followed correctly there shouldn't be a safety hazard or problem.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
efg
