Hello Seth,
Mr Shifta is the type of mover that attaches to the 'A' frame o the caravan. All 'A' frame movers have limited ability on slopes.
It is not about how much power thy have, but more importantly how much grip they have. Just like cars, power without grip results in wheel spin. However it is not the wheel spin that is of the greatest concern, but more the ability of the mover to stop the caravan moving when it is on a slope.
The problem is that all driven wheels can only deliver control if there is enough force pushing them to the ground. For a 'A' frame mover that is limited to the weight of the mover, plus the nose weight of the caravan. This likely to be only about 100Kg. This is not significantly more than the weight of an adult man.
As a guideline, if you think you, (by your self without the use of the caravan brakes) would have trouble stopping your caravan from running down the gradient, then the 'A' frame mover is likely to have the same trouble.
Add to that any conditions that reduce the surface and makes it slippy, (Water oil ice or leaves and gravel) then you may find that an A frame mover does not give you the security or drive you need.
Exactly the same physics apply to an axle mover, but here each wheel has approx. half the weight of the caravan pushing it to the ground, which provides much more control.
A frame movers are perfectly suitable for broadly flat level hard ground, but they may not provide a safe answer for gradients.
There are other things you may wish to consider;
You have to and 'A' frame mover each time you want to use it.
If you want to use it on site, you have to carry it and lift it in and out of the car or caravan.
'A' frame movers offer limited visibility of the rear of the caravan.
Axle movers are permanently available at home or on site, and most have a remote control that allows you to move around the caravan to se exactly where you are moving it.
If you are still considering an 'A' frame mover, then some of the supplier offer a home trial where they will demonstrate it. If you have a demo, ask them to guarantee the move will perform the necessary moves in all weather and surface conditions that are likely to occur on your premises.
