• Weโ€™re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. Weโ€™ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
New 13 pin socket won't power caravan rear lights
Hello,
I hope someone can help! We have just had a tow bar fitted for our ford S-Max with a 13 pin socket. It all tested fine at the garage where we had the work done. However when we hitched he caravan up, no lights at all work on the caravans when we hitch up using a split adaptor to the 7 pin sockets on another car, it works fine... So the caravan wiring is all ok, and the wiring in the car lights up their test board, but together it's not working.
We are very confused! Can anyone suggest anything? The caravan is a sprite major 6 sports style 2010.
Thank you in advance
Yes, just concerned about driving it around with no lights or indicators! Plus they are now shut and we wanted to go away in it tonight. We were hoping there may be something obvious that we are missing ๐Ÿ™
It sounds like the earth return wire for the lights is broken or not connected in either the 13 pin socket or the other end of the cable within the vehicle. you will find it is a WHITE Coloured wire.
Another thing to check is 1 does the caravan fridge work on 12volt with the car engine running? and do the internal caravan lights work when plugged into the car without the engine running? I ask because the fridge and internal lights have separate earth returns to the road lights.
