New awning for Abi Monza 1400CT - where to get one
PLW
Jul 22, 2019
Hi,
Our old awning is ripping and we need a new one for our beloved Abi Monza 2019.
Can anyone give us a guide on what generic awning replacement we need or do we need a bonafide Abi Monza one. If it's a generaic one, do we need possibly a size 8 or 9?
We've measured the A measurement (from the ground up to the bottom of the beading and then all the way round the beading including the pronounced return curve at either end and then to the ground again) and it comes to 845cm.
thanks
Sep 29, 2016
1,829
245
Abi Monza 2019
Not many of those around at that age ;)
Any awning dealer should be able to answer your question following a telephone call or an e:mail from you, lots of choice I guess.
PLW
Jul 22, 2019
Thanks Anseo,
Are there any dealers in either the London or Norwich area you can recommend?
thanks
1,818
Any awning the right size should fit but the correct length is from the ground up through the awning channel and back to the ground at the other end.
If you Google the model and the year you might find the correct length given. Do not use other years though as the length could be different.
PLW
Jul 22, 2019
Thanks Raywood,
We're struggling to find the year. We have a serial number though - 400013. Can't seem to find anywhere to look that up though. :-(
Feb 23, 2018
909
82
18,935
Measuring guide:
https://www.glossopawnings.com/awning-size-guide
We had a late 70's early 80's Ci Cadet 10, which was too small and curved for a proper caravan awning and too low for a porch awning. We used a camper van/motorhome drive away awning ('low' variant) which worked quite well.
Jan 19, 2002
1,672
516
worth contacting a few awning dealers to see what they might have lurking in their used section, but you do need to establish the size first. The bit of cord from ground to ground through the awning rail should give you a good guide then buy the nearest you can get. Can't visualise the profile of the van, but porch awnings can be bought in various widths so might provide an alternative,
1,960
Jeff Bowen awnings supply awnings for Eriba vans, which are small vans. If you measure your van Jeff may be able to advise.
