New RCD for BCA power supply
40
Anyone know where I can get a new RCD unit for BCA C Line power system fitted to Elddis Avante 2013. Present unit has failed to disconnect quickly enough when tested with approved tester.
Have contacted BCA but suspect they won't supply to individual.
4,590
Ray maybe these folk can help.
http://www.homesteadcaravans.co.uk/accessory-shop/parts-maintenance/electrical/
Hutch.
pmb
Jan 25, 2011
75
Any chance of a pic? I thought they were fairly standard in that the 2 cables go in at the top and out at the bottom. (or vice versa) I got one from cpc farnell but in the end it was my faulty charger unit that was tripping it. Is it mounted on a rail like the (expensive) one in the link above like mine was? Still got the one I bought which you are welcome to if it is a standard one and you are anywhere near Huddersfield. Any electrical place would have something similar.
Oct 8, 2006
2,043
720
In the power box on my Bailey Pegasus 462 the RCD (Chinese) is exactly the same size as a Schnieder at £22 from Toolstation. However it is connected to the MCBs with fixed insulated solid copper straps which I had to replace with suitable flex.
To the OP: my problem was simple mechanical tripping - nothing to do with current and a surprisingly common fault with RCDs. However if you know anything about electrikery think about how the unit in the caravan is likely to trip. You will need to be in contact with something that is at fault and live and an earth - and what is there in a caravan that is earthed and easily accessible? The only real chance of it protecting you is if you are using something outside plugged into the caravan supply and standing (ideally in bare feet) on wet ground or grass. It will NOT protect you against a EHU connecting cable fault - that is up to the pillar, assuming it too has an RCD!
