Newbie looking for advice on A4 Avant towing capabilities
Hi, I am looking to get my first caravan. It looks like it will be up to 1500kg. In fact, it may well be something like a Swift Challenger Sport.
I know my current car won't pull one. It is an A4 Saloon 1.8tfsi. Looking for advice on whether an A4 Avant 2.0tdi Quattro will do the job. I think it will but not having the car means I do not know for certain - don't have a plate to check under the bonnet!
A well known Dutch matching service seems to suggest I will be almost right on the 85% ration.
Any advice is welcome on this. Including alternative tow cars, like a VW Tiguan for example.
Hello James,
As is so often the case when people ask for tow car advice we are unable to be specific. If you look through the list of Audi cars (and this applies to most manufacturers) you will see that they often reuse the the name of a model, they populate it with different engines and transmissions, body styles and trim levels, and then some years they update a model with a different engine output or other details which can affect its towing capabilities.
If you dig deeper into the specifications you find that what appears to be virtually identical cars, can have very different technical specifications. The Volkswagen Audi Group inc Seat and Skoda, are notorious for using the same engine but with several different power outputs so simply quoting 2.0L is not enough.
To pin down the exact car (s) you are looking at we need We need:-
Make
Model
Year
Engine CC
Power output
Transmission
Body style(e.g. saloon, estate coupe or manufactures designation)
Trim Level(e.g. S, SE, GT etc)
I have yet to find a database of vehicle specifications that is complete and accurate, This includes those used by caravan dealers. So what ever site or data base you use, you cannot guarantee their results to be accurate.
If you can gather the information from reliable sources its actually quite easy to compare basic information such as towing ratio's. Reliable sources include data plates on the vehicle, the V5c Registration document, the owners hand book for the vehicle.
It is always a good idea to keep the towing ratio within the capability of the car and as small as possible. The UK caravan industry recommends not exceeding 85%. This is only guidance and not law, and sticking to it offers no guarantees of safety or a good match. Good towing is down to a lot of factors including proper maintenance, safe loading and nose weight trimming but probably most of all good driving.
Now you tell us you are new to towing a caravan, and based on the figures I have seen for some of the vehicles you have suggested I do have another concern. The cars you have suggested could have a Gross Vehicle Weight (Car fully loaded)of 2000Kg or more. If you are looking at a caravan with an MTPL of 1500, then the combined gross Train Weight or Combined Maximum Authorised Mass (MAM) is going to be in the region of 3500kg. If the combined MAM exceeds 3500kg you must have either Cat BE or B+E on your driving licence.
If you passed your driving test after 1 Jan 1997 you will not have BE or B+E unless you have taken the E extension towing test.
Hi
Well, I do not own the car but am looking at what to buy. Here is what I can find out about the car I have at top of my list:
Make: Audi
Model: A4
Year: 2013
Engine CC: 1968 (diesel)
Power output: 177 PS
Transmission: Manual Quattro (6 speed)
Body style: Avant
Trim Level: SE Technik
Unladen weight: 1605kg
Gross Weight limit: 2175kg
Nose weight limit: 80kg
I have not been able to find out the maximum gross train weight. Not sure this matters with the info above.
Also, I have BE on driving license.
The Swift Challenger Sport 544 has a MTPLM of 1435kg.
According to towcar.info, the kerb weight of the car is 1680kg.
This gives a ratio of 85%.
What are your thoughts?
I have to say that the help you gentlemen provide is outstanding!
Thankyou!
Hello James,
Not withstanding my comments regards loading, maintenance and driving the prospects looks good. The power to weight ratio and the fact its a diesel means it should have no prolem getting the outfit moving and keeping up with traffic.
Just take things easy, after all its caravanning!
Hi James, recently changed my Audi A4 Avant. It was the 170PS diesel, S line.
It towed very well, very stable, even though it was not the quattro version.
My van is a coastline (Swift) 470, MTPLM 1350kg. Bags of power in the Audi so you can keep up a good steady pace.
Just changed it for a Kia Sportage KX4, 180 bhp diesel, again tows well although the stiifer suspension of the Audi S line suited towing better I think. Never had any great traction problems with lack of 4wd in the Audi but i always had this feeling that one of the days I would get into difficulties pulling away on a steep slippery road.
The thing i like about the Kia is that the 4wd only engages when it is needed so helps with economy.
Bill D
