No 12v electrics
Just inherited a Hobby Prestige, probably 20 years old. All mains wiring working OK, but not the 12v system. Battery was dry, so fitted new battery. All fuses I can find are fine and charging gauge shows battery is charging. Selector switch set to caravan but still no joy. Any suggestions?
I just wondered if everything else was 230V but obviously its not that easy !!
You need to check the run of the live and earth from the battery for continuity and hopefully find either a break in the cable from bad connections etc or another main fuse
There may be an output fuse in the charger unit
Thanks John. There is an output fuse in the charger unit, but that seems to be OK as well. I guess I'll have to trace the wires as you advise and hope I can find a break somewhere.
