no indication
Mar 6, 2010
71
Just went to check our 1997 elddis for the new season. When i plug my car to the n plug all my lights ect work other than the off side indicator. My buzzer works in the boot as thou its working. I`ve taken the rear light of and replaced the bulb the buzzer stops when i remove it and started when i put a new one in but still doesn`t flash. Can anyone help? Cheers Mark
5,540
Mark
Check both the live and earth feeds to the light units.
Follow the cables along the caravan to the 12n plug and make sure all connections are sound.
If your 12n cable is wired to the car with those stupid blue scotch clips I suggest you change them for soldered joints.
Good luck.
