Hi, just aquired a new Avondale Dart 630/6 and am suprised at how noisy the in board water pump is is this normal, it sounds like a machine gun under a bale of hay!
Phil
Phil
Was 'Jonathan' but see we have two - so now JohnnyVGlad its not just me - have a new Lunar with an onboard Tank & Pump - had come to the conclusion that maybe the pump bearings were u/s because of the noise (and would have had pump changed at service under warranty).
The pump sits on four rubber mounts on the floor - do you reckon its worth further insulating pump ??
I guess it needs to be reasonably cool - so no wrapping in any kind of sound deadning material ?
Must admit I thought wife had run it without any water and had burned out the bearings - it sounds just like Philip describes.
Regards
Jon
Well glad i am not the only one with a noisy pump ! i have mounted mine which was on a plate with rubbers on. This has been mounted on to a rubber plate noise is not as bad, i have also made sure that the pipes dont rub against any part of the pump or furniture, which coulsd also amplify the noise. The result is a much quieter pump.Glad its not just me - have a new Lunar with an onboard Tank & Pump - had come to the conclusion that maybe the pump bearings were u/s because of the noise (and would have had pump changed at service under warranty).
Regards
Jon
