nose weight gauge help please
May 27, 2006
22
hi just been on ebay and saw one that looks ok made of metal and goes up to 80kg only 99p at present might be worth a look dont know what make looks about 2"square regards john
Nov 7, 2005
503
Hi Paddy, don't knock bathroom scales - the beauty of them is that you can check their accuracy by your own weight. If you follow this forum, you will find that one of the biggest quandaries in caravanning is ascertaining the accuracy of expensive gauges.
Mar 10, 2006
3,266
46
I bought a cheap nose weight gauge from Towsure, some years ago.
It is made of plated steel, has a stick on scale, which i wasn't impressed with, and is coil spring operated.(which i assume most are)
It cost
Mar 23, 2009
6
Hi, I've just bought and fitted the Alko integrated Jockey wheel and noseweight gauge. It's great, with wider and larger diameter tyre, it also has suspension on it making it smoother on the van during manouvering. Simple to use and read and for about
