nose weight guage
Hello Colin,
I am sorry to be so late responding, but I am currently in Canada on holiday so access to teh internet is limited.
I can understand what you are trying to say. So to try and clarify: - a little!
The law regarding MPTLM and vertical imposed nose load is crystal clear and uses the limits specified by manufactures for these elements to set a defining value against which an outfit can be judged.
However and where the law falls down is that it is not specific about how these values should be measured, and that is the part that is open to interpretation. So this is where the specification for level ground should be made, as should the method and specified accuracy of the measuring tool.
The science of measuring is actually far more involved than most people understand. There is a division of the British Standards Institute that shows industry how to evaluate the measuring processes they use and how take account and quantify levels of uncertainty. What most of this thread has developed into is identifying factors that increase the uncertainty of the measured value.
I think you know by now how I interpret the meaning of level ground, though to be more specific - the caravan road wheels and the reaction point for the nose weight gauge should he on the same horizontal plane. The height of the ball hitch above that plane should be the same as when the caravan is attached to the loaded tow vehicle.
Given that set of criteria, (and I know I have not given flatness limits etc) your first example would fail to give an accurate evaluation of the nose load.
For reasons that have been explained in other threads, the jockey wheel will give a different reading to the true value of the nose load. So both examples would fail to give an accurate reading.
With regard to your MPTLM figure, that is a matter for the caravan manufacturer to explain. I can only postulate that perhaps that after some time of manufacture they found that the original figure was causing some concern, so they opted to reduce it on later production, and when replating.
As for the maximum towed weight for a vehicle, Lutz has established that the MPTLM does not include the nose load, as that is carried by the car not the caravan wheels, so in theory you can load up to MPTLM plus the nose load. However, and here I might disagree with Lutz, is that as the nose load is an imposed force, rather than a mass on the hitch, derived by the loading of the caravan so it is in my view dangerous to make a simple addition of the two, so I opt to consider them as separate entities.
You are right to be skeptical about the abilities of the enforcement agencies to unravel the intricacies of measurement techniques, I think it is highly probable that their measurements methods could be called in to question where a case is only just over limit, but that would mean calling expert witnesses at quite a high cost, so rather than be on the limit aim just a bit lower to remove any chance of appearing to be over the limit.
I think John must have misunderstood me. I have never said that MTPLM does not include noseload. Of course, it does. What I have said all along is that noseweight is not included in the towload.
Regarding the intricacies of measuring noseweight, I think we are starting not to be able to see the wood for the trees, especially when questions are being asked how level the level ground has to be. Strictly speaking, whatever scales we use, we are actually measuring weight, not mass, but the law specifically refers to mass. One would find, for example, that measured noseweight up in the mountains or at the Equator is going to be less than on the Holbeach Marshes. As I stated before, if you keep your measured value a couple of kilos below the limit you will always be on the safe side to cover possible variations in measuring procedure and/or conditions. I think we are starting to split hairs on the subject.
hi john
hi lutz
thank you for your clarification and explainations I totally agree with both of you that it is better to be under the limit both for safety and legality say 10kg or so and could not comment on your respective methods of measuring as I have not done any field trials to find the best method of measuring it for myself.
the problem as I see it is that no two methods will give the same reading or the same reading twice and the variation can in theory be vast maybe up to 20 kg which is where my individual interpritation comment comes from.
as I said I do not have any level ground on which to take a reading exept a space that slopes about 1cm per mtr and unfortunatly cannot turn the van round to take two readings one up slope and one down so any reading I take will probably be wrong anyway.
the reason I wanted a definitive answer on measuring was so I could go somewhere flat and measure the nose weight exactly with the best method available and then go home and measure it again under normal condititions to see how far out it is, in this way any difference will be obvious and therefore calcuable for future reference.
but as of yet no method seems accurate enough to use and if that is splitting hairs so be it.
colin
Having talked about the degree of 'levelness' of the ground, the height of the coupling, windspeed, etc., as factors which may influence the readings, let me just say that the list is not complete. It has been proven, for example, that the weight of a caravan can vary by as much as 15kg depending on the relative humidity of the air. The insulation can accommodate up to this amount of moisture out of the air without actually being recognisable as damp so long as it is uniformly distributed. I doubt whether, even now, we have covered all conditions which can influence the results. Therefore, even with the most sophisticated laboratory equipment and trained personell you are always going to get variations in measurement readings. But this would apply just as well to the authorities (police) should they wish to check.
All very fascenating stuff, but we are still at the mercy of the measuring apparatus.
While bathroomscales have a reswolution of say 1kg. this does not necessarily mean they have an accuracy to 1kg. Further, they never define accuracy.
Industrial measurements define accurcy usually as a %age of the actual reading, as a % of the full scale reading, or for some specialised measurements at a specific point on the scale.
A current advert for a nose weight gauge claims 3% accuracy. It has a capacity of 120Kg. Unfortunately it does not state whether the accuracy figure means plus or minus 1.5% or plus or minus 3% or whether the 3% is 3% of an individual reading or the full scale deflection.
Most probably the latter, so you could have an error of 3+kg even when measuring a load of say only 20 kg.
But I suggest this is all getting far too complicated and is likely to deter people from trying to get noseweight into a safe zone rather than a specifc measurement, for which the level ground bathroom scale method is probably as good as anything, particularly if you make morethan one measurement and then either average the readings (if fairly close together) or re-arrange the scales etc if not.
Hi Everyone
i'm new so hope i have a worthwhile viewpoint. i was considering using a trolley jack to support a flat piece of wood - on which i place bathroom scales. one more piece between the hitch and the scales. i was hoping to adjust the height with the jack to coincide with the car, while leaving the jockey wheel just off the ground. Opinions?
As your question didn't get answered, here goes. Assuming everything on level ground and outfit loaded ready to go, measure the towball hitch height from ground-somewhere below the ball. Hitch the van, so the outfit is settled. Measure again to same point. Take one reading from the other and obtain packing block of same size to place under the gauge. This ensures you record the noseweight actually being applied in the running position, whereas your method gives a theoretical reading,because the van is not hitched.
hi ray s
I don't dissagree with what you say but it doesn't answer the big question what is accurate and what is not??
as I was explaining to lutz I dont have any level ground and I cannot turn the van round to take multiple measurments the best that can be done would be to take the van to tesco's car park when it's shut and test it there,then take the van home and try it again on the drive (nose down as I have to reverse it in with the car)and see what the difference is:-great so I then know how to calculate the weight up/down in relation to what it was on tesco carpark.
the trouble is without an accurate reading in the first place I cannot tell how far out it was/is which makes any further adjustments on the drive worthless.
if you see what a mean
And all I was was saying is that there is no such think as an absolutely accurate reading unless every condition that could possibly affect the measurement is specified and fulfilled. I can't imagine that anyone is going to wait until it's an absolutely calm day and also check the ground that the caravan is standing on is level with a spirit level first. It's a matter of using reasonable judgment, how much the conditions could influence the readings and then make appropriate allowances.
When it rains, puddles remain on the place where my caravan is standing. As the road surface is relatively even, that's good enough for me regarding the level ground issue. And, after having checked once or twice with the bathroom scales, if I can just lift the coupling comfortably while straddling the A-frame I reckon I'm close enough to the 75kg limit.
Just for a laugh - shall we ask Jeremy Clarkson (hee hee hee) to "TRY" and calculate the the nose weight of a caravan?
I wonder what ridiculous results "HE" would come up with.
Colin.
I wonder, would we be btter off if we did away with all these damned European Directives and went back to good old British Standards and British rules and regulations. Hmmm.
Hamer
For better or for worse, those days are over, Hamer. It's no use yearning for the past when things are changing faster than we can catch up with them.
