- Mar 14, 2005
- 19,278
- 4,473
- 50,935
Just a general note.
Some caravan manufacturers will quote a nose weight figure for their caravans, but it is only ever the caravan's ex works nose weight, becasue as soon as you add anything to the caravan (i'e Gas bottles, battery, flush water in the loo yet alone your personal effects such as bedding clothes food drink, unless everything is loaded directly above the axle which would be physically impossible , the balance of the caravan around its axle will change and that will affect the caravans nose load.
It is an essential part of caravanning or towing any trailer, the driver of the outfit is responsible for making sure the load in the trailer is not excessive, and is placed to minimise instability factors but also to create the necessary nose load for towing. There are guides about how to load a caravan, to best effect, but they are only guides and not prescriptive.
The nose load is likely to change every time you load the caravan differently, so don't think it's a one off job to check it.
Both the trailer and the tow vehicle will have individual maximum nose load limits. In every case if there is a difference between the trailers and cars limit the lowest value is the limit for that particular outfit.
