Noseweight gauge
Jun 1, 2008
98
Anyone want a noseweight gauge free?? come and get it.! What a waste of money. Having only had the Fleetwood a month and about 100 miles towing I duly checked the noseweight with the tubular compression type gauge and it read 85kgs, fine I thought but I am not a small weak chap by any means and can easily lift 85kgs but lifting the nose of the Fleetwood was a struggle so I decided to check it wit the bathroom scales.
Placed a piece of 3x2 across the scales and an 18" length of 3x3 under the nose and slowly lowered the nose until the weight was on the scales,,,,,Result ,,,,115 kgs.!!
They are now in the floor mounted open top recepticle, with a bit of weight shifting got it to a true 85kgs , with the scales,
If you have considered buying one of those plunger gauges, !!!
Nov 28, 2007
490
12
18,685
Our Elddis has one built into the jockey wheel. Hopelessly inaccurate, 100kg is actually 75kg.
Jul 30, 2007
1,461
404
19,435
Hi Tom.
After reading your post I decided to go and check my noseweight too using one of those gauges.
I purchased our 2007 Bailey Pageant Champagne 2 weeks ago and have not checked the noseweight yet.
The reading was 88kg.
Great I thought.CRV has a maximum limit of 100kg so should be fine.
I then used our bathroom scales and also borrowed neighbours scales to re-check.
Both readings were 115kgs!!!!!
After moving 2 armchairs,empty water carriers,2 pillows and 1 quilt to the rear washroom of caravan,I then had 2 readings of 90kgs.
So i agree Tom,those noseweight gauges are not really that accurate.
Adrian.
3,983
Hello All,
I have yet to finds any commercially available nose weight gauge that is height adjustable and both consistent and even reasonably accurate , compared to the bathroom scales approach.
It is particularly sad as they promise so much, yet fail to deliver in an area that is actually governed by law, and if you get it wrong, it can be points on your licence.
8,224
Has anyone triied the Milenco guage which is supposed to be calibrated and have greater accuracy?
Apr 26, 2010
325
I have the milenco gauge and when I measure my weight by lowering the jockey wheel it comes out at the same hight as my tow ball.
Therefore I see no difference if I used bathroom scales and will stick with my milenco.
Towed 3,600 miles return trip and no problems at all so can't be that bad.
Apr 26, 2010
325
3,983
Hello John,
Your reply concerns me:
Simply relying on the case that you have had no problem when towing does not confirm the value of your nose load is correct or whether it is legal.
As the Milenco is a spring loaded strut, its height varies according to the applied load, so whilst it may be correct for you with one particular caravan configuration, anything that changes the actual nose load will also change its height on the gauge. Principally it is highly unlikely that the compression rate of the gauge will be the same as your cars suspension, so it will not be accurate for any other configuration.
I do concede it is far better than nothing, but it is also far from being the best or most accurate system.
Milenco make some quite impressive claims for their product, but some of them do not ensure compliance with the legal requirements the driver faces.
Jun 23, 2008
159
When I bought my brand new Swift last year I decided to check nose weight (as it came ex-works) with my gauge, you can imagine the consternation when it sank out of site.
Checked with the old bathroom scales method (I 'calibrated' them by checking with a known weight) the 'proper' gauge read about 20kg higher.
Bill D.
8,224
Bill, at least yours was erring on the right side so as not to overlaod towbar or A-frame. Perhaps PC should do a consumer test and report it in a future issue.
Sep 25, 2009
372
Hello Other Clive,
They have done this, the Milenco came out top in their Awards 2010, hence the reason I purchased one. Whilst being new to caravanning, I have found using the Milenco easy to use, as it is the correct height and fits directly in to the hitch head. I have also been happy that the results shown, have been accurate
I personally put a lot of faith into recommendations from magazines, whatever I am looking for, and also purchased the Halfords Torque wrench, following a product review in PC.
Best regards,
George
Mar 10, 2006
3,274
47
I bought a cheap nose weight gauge from towsure ten years ago, in side is a spring, so very basic, however it reads the same as my old bathroom scales, conveniently the scales give me the correct height for my nose gauge, so rather than bend down to read of the gauge i use the bathroom scales, no reading glasses required!
so my experience appears at odds to all previous posts.
Jun 1, 2008
98
There seems to be a massive grey area on these things and lets face it that this is one area that we shouldn't get wrong! As for the previous post about towing for 3600 miles without a problem, and with respect< I would say that you may be burying your head in the sand. Point in fact that I towed a Fleetwood 560/4 over 300 miles (from the dealers in S.Wales) after checking the noseweight with a milenco spring type gauge tleiing me that it was within my limits only to find that the gauge was out by over 35kgs !! It may well have towed it happily for 100's of miles but NOT SAFE.
That to me is in-excusable, not only putting myself and family at risk but other road users.
Apr 26, 2010
325
Tom
First let me say that I do not bury my head in the sand at any time regarding any matter and safety for me is a premium.
That is why I had an ATC system fitted to my caravan at extra cost and a trailer control system to my car at extra cost.
Both to avoid possible situations that could endanger either myself my family or others for that matter.
I have faith in my Milenco gauge and what it was telling me for a number of reasons which are as follows:
1. double checked against a bathroom scale method
2. The jockey wheel is an inflatable wheel and the tyre formation with weight on it
3. when using the motor mover the movement of A frame gives an indication of how it is loaded when travelling over certain objects.
Finally my question is should legal action be taken against the manufacturers of this type of equipment as by what you say they are falling foul on a number of accounts:
1. the equipment is not fit for the purpose in which it is intended
2. it is misleading in what the producer is stating of its capabilities
3. it is endangering the public for which the manufacturer is liable
if any of the above is correct why are they on sale and why would any manufacturer take the risk of producing them and any retailer the risk of selling them.
or does the manufacturer or retailer rely on the user
Apr 15, 2008
140
I had one of the red square tubular noseweight gauges, the type with a spring inside. I'm not sure now where it came from. Its completely useless, the readings from it were way out. I always use pieces of wood and a bathroom scale. I'm surprised such poor noseweight gauges are on sale. They are a device by which people make safety critical decisions.
1,971
I agree with John above. If manufacturers are selling a device which purports to measure noseweight then, within certain tolerances, those gauges should measure noseweight. Otherwise they would surely be liable under trading standards or something?
mel
3,983
I’m sorry for the delay in replying, but there seems to have been some delay in getting all the posts from the old forum into the new one, and this thread seems to have become somewhat disjointed.
There are four basic problems with all the commercially available nose load gauges I have seen;
  • Actual accuracy and consistency, (reports of variation of +/-30%)
  • Clarity of the graduations (the ability to interpret the intermediate values)
  • Changing length due to the applied load ( the natural effect of a spring under load)
  • And the inability to adjust the length of the device to exactly match the load height of the cars tow ball
When the nose load is applied to the car, the tow bar drops because the suspension of the car has to adjust to match the nose load force. The bigger the nose load the further the suspension drops.
Exactly the same happens with the commercial nose load gauges. But there is a difference because of how far the gauge drops with the same load applied.
Unfortunately and most importantly, the nose load of every caravan varies depending on how high the hitch is.For a single axle caravan, if you were to drop the hitch to the ground, you need more force to lift it, than when the same hitch is at 400mm from the ground, and in some cases if the hitch is raised as far as it can be, the nose load actually changes to lift and the caravan will sit with its tail on the ground. This is all to do with the loci of the caravans CofG relative to the main wheels when the chassis is tipped.
The situation is even more complex for TA caravans, and the change between positive and negative nose loads can occur over a much smaller height range.
Consequently the height of the hitch is very very important in establishing what the actual nose load is applied to the tow car.
Most commercial load gauges have a much larger compression rate per Kg than the suspension of a typical car, thus you may be fortunate in finding that you caravan when it is loaded in a particular way settles at the same height on the car and the gauge, but make any changes that affect the nose load, and that happy coincidence will no longer apply, and the reading you get from your gauge will not represent the actual nose load applied to your car..
For those that claim to always load their caravan in the same way, consider that an empty gases bottle weighs less than a full one few bottles of wine on the return journey etc. Such factors may take you into an illegal loading situation.
The advantage of a pair of bathroom scales over a linear spring is that the actual movement of the weighing surface is in the order of a few mm for a weight range of 0 to 150Kg, thus the height error is minimised, compared to 100’s of mm.
It is also fairly easy to re calibrate bathroom scales using a water container with a measured amount of water to act as the test load.
What is needed is a stand with a load spreading foot to stand on a pair of domestic bathroom scales, and a standard 50mm ball at the other end that can be fitted into the hitch. The height of the stand is adjustable (preferably like a screw jack) so it can be fitted and easily and safely adjusted whilst in position to match the actual towing height.
I claim Copyright to this idea.
In response to John_37456491, your list of points
The compression of the jockey wheel is a very poor indication of the applied load, it relies on the surface it sits on, the degree of inflation, and the accuracy of your own judgment. Coupled to the fact that jockey wheels are notorious for loosing pressure, it is not a very safe method of judging nose load, and I seriously doubt that you could reliably detect even a 20Kg difference by that method.
The reaction of the A frame when using the motor mover, is again a very poor guide to the load imposed on it.
Together these methods may give an indication but you would be very unwise to rely on them as your defence if you were being prosecuted for over loading.
As for the actual sale of nose weight gauges,
In my view I have not seen one that is fit for purpose of adjusting to match the towed height, and to repeated and accurately measuring applied nose load of a trailer.
Your last point is not valid. The gauge its self is not dangerous. It will not inflict harm or injury to the user or to the public. It is the user who misinterprets the reading that is the potential danger.
You must also appreciate that there is a difference between illegal and dangerous. A product or condition that is dangerous is almost certainly illegal, but something can be illegal without necessarily being dangerous.
Apr 26, 2010
325
I do not want to pursue the conversation as to whether one should or should not use a nose guage as I am sure everybody will have there own opionion on this point all I can say is I am satisfied and happy to use my Milenco for my specific outfit type.
However I think that we should cover one point for other readers of this thread in regards to what is and what isn't legal.
correct me If I am wrong but the nose weight can be between 4% and 7% of the unladen weight of the Caravan
However must not exceed the maximum permissible by the towing vehicle
and it is only this measurement which can be determined as legal or not
As the 4/7 measurement is a guideline for loading
(Please correct me if I am wrong)
3,983
Hello John,
The EU stipulates that the MINIMUM nose weight you use for towing should be 25Kg or 4% of MTPLM which ever is greater.
The maximum nose load you can have is determined by the lesser of the car manufactures tow hitch limit or the trailer manufactures chassis limit.
It is generally accepted that an outfit tows better with a nose load near the top of the available range.
7% has no legal position, it is just a guideline based on rather old and now out-dated considerations, but it is a perfectly acceptable target if you can achieve it within the criteria above, BUT it does not guarantee a safe or good outfit .
Apr 7, 2008
4,909
You mean like this one i made earlier !
May 21, 2008
2,463
Nose weight guages are a grey area as none of them are realy calibrated as such, because that would entail a periodic re-calibration, to qualify as an ISO9002 product. What Milenco offer is aguage that is tested in production and complies to a pre-determined manufacturing standard.
The basic info is correct to say that under EU laws ther must be a minimum 25Kg down force on the trailer hitch. Also you can not exceed the lower figure of the maximum hitch weight of the caravan or the towbar down load on the tow car. So If your car has a 100Kg towbar load and your caravan has 85Kg hitch weight, you use 85Kgs as your max noseweight situation.
As for using bathroom scales Vs noseweight guages, I use the scales to set my van to 75Kgs nose weight, which works very well for our outfit. Then I use my noseweight guage which fits over the tow ball and into the hitch of the caravan. Luckily for me the pointer arrow sits at the 75Kg mark but if it didn't, all I would do is to draw a match line on the body of the guage to indicate the tested weight level so that I can use the hand size guage anywhere.
This method will work for any axle configureation even triple axle Ifor Williams trailers as you are initially checking the nose weight at the ball height of your car and any error caused by the alternative height of the guage is automatically taken into account.
Without getting into the science of pitching up and down load changes, they do occur, but all you can do is measure a static mean average weight anyway. It is upto the individual to experiment with more or less weight to achieve the optimum tow stability for their outfit.
Atb Steve L.
3,983
Yes sprocket, you get the rights proven by Prior art - I do recall seeing this before but I hadn't clocked the height adjustment - Spot on. - can I make it under licence ???
3,983
Hi Steve,
I recall that you have written about the gauge you use previously, and as I have pointed out previously, the height difference it introduces does make a difference. Your point about using it as a comparator, rather than an absolute gauge makes sense, but that will only work for a SA, as the loci of the CoG is an arc with the centre or radiaus at the main wheel.
The assumption that it will work equally well for a multi axle is wrong, as the loci of the CoG as the trailer is tipped is far more complex, and in fact the more axles the more critical hitch height becomes. I have seen many TA's that if you lift the jockey wheel, the hitch doesn't drop to the ground but hangs at some point in mid air (nose load is zero at that height), and by the same token when it is lifted a few cm'sit very rapidly becomes very heavy.
May 21, 2008
2,463
Hi John & Sprocket.
First of all an offcut of 18mm plywood cut to the size of the scales pad with a notch in it to allow the dial to be read is qick and simple. While sprocket's gadget is well engineered and strong enough to hold up the Blacpool tower and your theories John are valid if one has a degree in engineering science. The time wasted waffling over the technicalities of weighing the nose of the caravan could be better spent on a site somewhere.
When your pulled over by VOSA all the do is place a scale under your jocky wheel and wind the wheel down to un couple the car, if your lucky they will let the car roll forward a few inches and wind the hitch to the height of your tow ball before reading the scales. At least that is how my caravan's have been weigh'd and that has been both single and twin axle vans.
All you are required to do by law is to ensure that while your vehicle is on level ground (by which I mean the highway), the hitch download is not less than 25Kgs and not more than the lower of the max weights determined by the caravan maker or the car tow bar manufacturer. By doing the check in a simlar manner to how VOSA do, you won't be far wrong. By the way, they generally won't prosecute for this, they advise and allow you to re-distribute the load in the caravan to get the weight correct.
Atb steve L.
3,983
Good morning Steve,
I agree, if the indicated nose load was only marginally out, VOSA probably would 'educate' the driver and get him/her to re-trim the caravan. But I suspect if the loads were grossly out, it is also likely other non conformance's would be present. However there is nothing stopping VOSA adopting a zero tolerance, but if a prosecution was based solely on the methods you have described, a barrister would have a field day in court.
