- Mar 14, 2005
- 18,693
- 3,946
- 50,935
I have decided to make this post becasue it touches on the subject of engine pollutants that has been discussed in some detail in the past, and I have used an assumption that now in the light of what follows seems to have been incorrect.
I had previously assumed that for properly adjusted engines that those have low MPG are likely to produce more pollution per mile. But a recent test conducted by the Consumer Associations has thrown that assumption aside.
The Association has conducted a test where they have compared the NOx production of different manufacturers products in two categories Euro 5 and Euro 6. They in each category they report a difference ratio of about 600% between the worst and best. The short report does not specifically state that all the models tested were Diesel, but that is the clear inference, as only the only fuel actually mentioned is diesel.
The report neither tells us models and engines sizes so the actual figures produced so the actual results are rather vague, but they do tell us
"It also might surprise you to learn that our unique testing has revealed there is no strong link between the level of emissions your car creates and its MPG (fuel economy). We’ve even found hybrids that produce high levels of toxic emissions.
Read more: http://www.which.co.uk/news/2017/03/which-tests-reveal-the-worst-diesel-cars-for-air-pollution/# - Which?"
Its important to understand the Which? report only looks at the NOx and whilst it is a serious pollutant, it's not the only one that we should be concerned with.
