Colin
Thats a hotch potch of ideas and some have no relation to the number of spokes in a wheel.
colin-yorkshire said:
I think it is to do with harmonics and aesthetics. playing a role in the design due to the concept of uneven being a sounder option. [gobbledegook one may say] but there is a sound engineering thinking behind it. for example. a 3 legged stool will always sit firmer than a 4 legged one if the ground is uneven.
Perfectly true about stools, But harmonics???? Everything has at least one fundamental frequency at which it will vibrate, and it will most likely produce harmonics of that fundamental. I cannot conceive resonance frequencies and their harmonics of a balanced wheel having any significant amplitude or transmission back to the ears of occupants or pedestrians nearby.My strongest suspicion is all about wheel strength and aesthetics.
wheelwrights found using odd numbers of spokes made the wheels stronger and simpler to make.
Really? Odd number of spokes are stronger even? So 5 is stronger than 6?
No, It's a fact that more will share the loads better than less, but that has nothing to do with the numbers being even or odd.
It is easier to work with even numbers becasue without quite accurate machining or jigs, getting evenly spaced odd numbers of spokes on a wheel is a real skill, but even numbers area lot simpler.
fan blades are always odd numbered as even numbers set up vibration as the fan slices through the air causing a buzz, due to imbalance...
No they are not always odd numbered! I have several examples of fans and propellers with even numbers of blades. Every fan blade as it passes through its medium, (air or water) creates localised disturbances to the fluid, its those disturbances that are transmitted as a shock wave through the medium, and in the case of air, is what wee hear. The next blade will do the same. The repeat frequency of those shock waves is determined by the rotational speed of the fan shaft multiplied by the number of blades on the fan. Having an odd number does not magically reduce or stop those disturbances.
