on board water tank
Apr 20, 2011
22
Is there any way of connecting a hose direct to the caravan from a water tap to fill the onboard tank ? the few sites we use are all fully serviced and i would like to do away lugging the aqua roll about, my caravan is a bailey senator indianna 2007 the tank has an overflow so it cant be over filled would this do any harm to the onboard pump ?
thanks in advance
chris.
Aug 5, 2010
30
You can connect the van to an external water source, with one of these from Bailey online parts shop part number 1132029, the manuel shows which position the levers have to be in by the pump, I would think that this by passes the water tank, not tried it, but the kit came with our van.
Connie
Apr 20, 2011
22
great advice thanks very much ordered one today, i was going to up date to the aqua roll valve but mine is the the 20 litre without
the extra screw connector so buying this would have cost me well over a hundred pounds for all the kit and i would have had to still lump the aqua roll about !! i was sure i had seen someone on site last year using one of the above items but not knowing the part number or what to search for is pretty hard, once again cheers
chris.
