Many thanks to those who have taken the time to reply. I have tried some of the suggestions made with varying degrees of success.The problem seems to be that it is basically a very noisy pump, when unscrewed from the floor and operated, I can hold the pump in my hand and feel very little vibration but it is still quite noisy. I did try and tighten the four screws which hold the pump to the floor but found that tightening them just drove them through the rubber bracket, I removed them and added washers before re-tightening them and have found that has helped a little. The link to the forum thread about the non-return valve was interesting, I will have a look for that but I'm not too sure exactly what the return valve will look like and don't want to remove the wrong part. I have also wedged pieces of sponge under the pump to try and absorb any vibration but didn't notice any difference with this. The noise seems to be worst immediately after the tap is turned off, when the pump continues to run for a very short time and makes a real racket.For many years I kept aquariums all of which had either internal or external water pumps for filtration, these were very quiet unless a fault developed in the impeller wheel, they then made a noise very similar to what this pump is making. I don't know if the internal workings of caravan pumps is similar to aquarium pumps or not.The caravan dealer is more than happy to check it out for me under warranty but is fairly certain there is no fault with the pump.
Thanks for your comments.
Robert
