Hi,
I bought a 2017 Seat Ateca that came with a Oris detachable towbar but never received a manual. It appears to be an older model as it came with two keys that are similar to a key used in a padlock. I have two questions. Firstly does anyone know where I might find a manual for my towbar. Secondly the towbar appears to work OK and locks into the slot on the main frame without any issue. I have established that the key requires to be in the locked position before pushing the towbar up into the appropriate slot and when you do this the side locking ring rotates as designed with the two white marks line up. The towbar is definitely locked in. The next thing is to remove the key which is still positioned in the locked position. But my issue is that without inserting the key into the key slot I can rotate the appropriate side device which then releases the towbar from the main frame. Surely that's not right as that means anyone could just remove my towbar and walk off with it. I have tried everything to lock the towbar into place and not matter what I do I can't get it to lock in and requires the key to unlock it. Can anyone help or is that how they work?
