oven temperature
Nov 2, 2005
1,485
19,185
Hi Guys,
My oven doesn't seem to be getting hot enough. The flame isn't very hig, I have a little poky thing which has helped. But how do I get the jet thing out to give it a good clean?
Sep 5, 2006
22
Hi Smiley
This could be lots of things causing the fault even a faulty regualtor
If i was you i would book it in with the proffesionals let them fix it. cant be to careful with gas.
Robert
Nov 2, 2005
1,485
19,185
Hi Robert.
Weve just had the van service and gas was aok. So no blockages there. But we noticed when we went away. Just though someone might know how we can get it out to clean.
Nov 7, 2005
503
Hi Smiley, we've had two caravans in recent years, and in both my wife has been frustrated by the comparatively poor heat in the oven - reckons it takes much longer to cook things than at home. Surely, it's just that the smaller appliances in the van, and reduced gas feed, are just no comparison to what we enjoy at home.
3,878
A gas oven is controlled by the thermostat - if it's working correctly it shouldn't make any difference whether it's a caravan or domestic oven.
Smiley - your oven needs checking by a competent engineer.
937
The first thing about gas appliances is DO NOT poke anything around the jet or burner.
They are critically set to deliver the right combustion mix of gas and air, and by enlarging any part of it, you may well be causing a very dangerous situation.
Get it checked for correct operation by a suitably competent engineer.
The service,as it is, simply sees that it is lighting properly, not its cooking ability.
Dec 5, 2006
120
Hi smiley
I know it may sound obvious, have you googled the oven's manufacturer? you never know they might supply part's i.e. thermostat
good luck
