I think you will find that this is an auto gearbox, Lutz. The gearbox in my American motorhome is auto, with the top gear being described as an overdrive. It probably isn't though, just as likely being the top gear, which is capable of being locked out.
Richard, you should be able to tow with your overdrive on, but if you are faced with some demanding roads such as those that pass through mountains it might be better to lock it out. If the jeep can run in 2wd and traction isn't an issue, everything should be fine. Check with your hand book though as a couple of 4x4 manufacturers advise using 4x4 when towing.
