Panoramic window leak
Sep 7, 2025
Hi
I have a leak in my panoramic window on my 2014 Elddis Shamal which recently while on holiday during a heavy rainstorm became quite severe.
Could you please advise if there is a possible diy solution or is it a professional project?
2,260
Does the window open? Is the rain coming through a crack in the window or via the seals?
Sep 7, 2025
Hi Mel
No the window doesn't open, it is the one above the 3 front windows with a surround which is sealed with sealant and I suspect that the sealant may have started perishing.
2,260
I can’t help but I will move this thread into the Technical section where it might get more traction
485
396
935
It can be replaced completely if you have the tools and the time
see video
View: https://www.youtube.com/watch?v=Zv2DJR-2ejQ&t=576s
also
View: https://www.youtube.com/watch?v=72_ShGGjXxg
I also have done the cheap fix , if you look at the first video where, having cut the majority of the window away with a multitool he then shows you where the window is bonded to the caravans roof ,with a further overlap and you can see the accumulation of dirt . Without touching the window and working from the outside of the window I first checked the window for any cracks and then degreased the caravan roof and window edge with IPA and then applied a generous bead of sikaflex 554-black around the edge of the window to seal the complete outer edge of window to form an additional seal (it took two cartridges). Then using Brake cleaner(ether based ) smoothed down the surface to make it look neat.
