Hi, we are getting a Pegasus gt65 and are taking a bbq with us when we go away. I know it has an external bbq point but do I just attach the hose from the bbq to the caravan bbq point via a jubilee clip?
http://www.caravantalk.co.uk/community/topic/27364-external-gas-bbq-point-on-senator/
Chris
There are two different fittings depending on the caravans age. See above
Link.
Earlier models had a push fit into the BBQ point with a on off tap.
Newer models use the Bullfinch.Price similar.
As soon as you see the exterior of the point you will know which one you need.
If it's a new 'van, it should come with the fitting. Make sure it has, also the key for the locking wheel nuts and the sleeve to fit in the 13 pin plug to line up the splines (they sometimes get misaligned).
Just noticed you said it's a 2014 model. Any decent owner will give you exactly what the 'van was supplied with as new.
