Poled awning or air
Sep 22, 2025
We have a Bailey Ranger 500/5 and currently a Kampa Rally 200 awning
It's finally seen better days and the fabric is starting to go, had it a long time
So we're looking for another porch awning, a slight bit bigger and have narrowed it down to these 2 (looking at under £400 budget)
We tend to stay most times at Camping & Caravan Club official sites on hard standing
I don't mind whether it's poled or air as am happy to put up either, just want the best quality for our budget
Would also look at getting uprights and monsoon poles if needed
We tend to go away in the February and October half term (Norfolk) and use it during the summer as well so wanted something that wasn't too lightweight and will be ok for the wetter/colder months
I was initially looking at the Dometic one then the Sportlite popped up and looked a good deal, as wasnt looking at air ones, as they didn't seem to hit our budget
Any help appreciated, thanks
Sep 4, 2011
571
348
19,135
Having had both the pegging requirement amounts to the same effort The Outdoor Revolution was quicker to blow up than time putting poled awning up.
It also withstood heavy winds better by being able to flex about. Ours withstood 60 mph winds when poled awnings on site had collapsed. The only disadvantage was the weight when threading through the Caravan awning rail with the combined fabric and air tubes.
2,213
If you like Vango awnings then their outlet site Camping Recycled is worth a look. Refurbished or ex display at a decent discount. We got a tent for our daughter that was in excellent condition at a bargain price. You also get a further 10% off with CAMC membership.
8,964
I’d agree as I bought a Vango Beta XL tent from that outlet and it was hard to even distinguish it from a new tent. Excellent value.
Reactions: Mel
3,466
I'd suggest that whether an awning collapses in high winds depends far more on how it's been erected and pegged down than what type of awning it is.
Sep 4, 2011
571
348
19,135
Away 10 days ago in those high winds and two Awnings with metal poles opposite us were down with the roof poles bent,
3,466
I've noticed that some caravanners don't tension their awning canvas properly - if they don't take it down in high winds then damage is inevitable.
3,999
1,746
With awnings that is most probably best served using your budget on a used, or better a hardly "used" high quality awning. Plus, we are close approaching the time of the year where money for used awnings goes further.
Sep 22, 2025
How did they compare quality wise?
Did you feel one was more “premium “ than the other?
I’m fine with the weight of them
Sep 22, 2025
Any tips for what to look for in used awnings or watch out for?
Sep 22, 2025
The only one in our budget is this
Says patch on the roof and some dirty marks. So hard to know without seeing pictures, but presume it’ll be off a high standard if it’s been refurbished by them
571
348
19,135
With the Air awning it took the two of us to get it started in the Awning
rail .Once it had started going along the top was fine. But on your own pushing it upwards if you let go a bit to get another hold to push up further it slipped down again with the extra weight, But once fitted preferred the Outdoor Revolution which actually is lighter than many Air Awnings,
Reactions: andy500
3,999
1,746
I have and would unhesitatingly recommend an Isabella Magnum, if it is a "quality" awning you are seeking. These are poled, now with carbon fiber reinforced tubes. The fabric comes in unzippable sections adding to its in use practicality and the ease of handling. The zipped sides also enable fitting annexes if needed.
These now come in varying sizes but ours 23 years old* is the smaller of the sizes, these older ones used GRP tubular frames.
* that in itself testament to the UV resistance as its been extensively used , in number of times and their durations.
5,258
* that in itself testament to the UV resistance as its been extensively used , in number of time and their durations.
My Magnum is 20,years old. Carbon X poles which I believe are part carbon fibre and reinforced fibre glass. She has with stood Somme very high winds . As you say about pegging the Isabella storm straps and pegs are legendary. Never had a problem.
We still have an early Kampa Rallye Air in the loft with a failed bladder. The fifth one to blow.Kampa did send a replacement FOC but in truth we could t be bothered. Too heavy to pull through the rail. I believe with their new owner Dometic, these air awnings may be more reliable.
Reactions: Kevin M
Oct 21, 2020
402
244
4,935
Our Isabella is very similar DD, great quality and easy to erect and peg down.
My main gripe with the Kampa Air Awning was the weight of it in the bag!
Kev
2,560
This might be in your budget we have on our seasonal caravan at present
Quest Falcon 325 poled awning and so far it been brilliant last weekend there was strong winds and it stayed up someone else has got one now he was so impressed .
5,176
The Dometic awning is a rebranded Kampa awning. Isabella or a Ventura awning are the nest and very long lasting. Even second hand they will last years.
May 15, 2023
152
135
1,635
Whatever awning you choose, I would recommend purchasing some screw in pegs, a godsend when you encounter hard ground, you will require a cordless drill, the pegs come with a drive socket.
2,560
That what the previous owner of our new to us a Isabella Magnum Coal 250 has stood up to some high winds it never moved and he given me a full set of pegs and storm straps and information how to put it up .
1,244
795
1,435
I got a box of them from go outdoors and used them on recent trip to Perth, they struggled to go into a hard standing pitch, that was with a impact driver as well.
