Polestar 4 Long Range Dual Motor as a tow car
Jul 23, 2021
1,041
988
5,435
So we finally got to test the Polestar 4 as a tow car this week. Not a huge trip but far enough to get a good feel. Due to a mess up on my part with the home charger we left home last (South Northamptonshire) on Sunday with just 71% battery and a 115 mile run to Danebury CL near New Milton in the New Forrest. However it gave us a good opportunity to test out the chargers at Winchester on the way.
The Polestar 4 in LRDM (Long range Dual motor) spec, has a 101kWh (96kWh usable) battery, 400kW / 536 bhp motors, 686Nm / 506 lbf- ft torque with AWD. Towing limit is 2000kg with a 100kg max towball load. So lots of capacity to tow our 1550kg MTPLM Bailey Unicorn S3 Vigo.
When we got going, there had been a bit of rain over night with wet roads, and some rain persisting. It had also been cold, so the battery was chilly, and a large unit takes some time to warm up, so I wasn't expecting peak performance. Deploying the fully automatic towbar was simplicity its self, with it unfurling from the back of the car at the touch of a button in the boot, and locking into placed with a satisfactory whir. The reversing camera (while missing the centre line guide on the Polestar 2, (come on Polestar - add it over the air please), made it easy to hitch, with a distance readout on the screen in cm from the closest point.
The trailer light check offered to start automatically, but some how I messed up the activation, so a manual one ran (I did manage to get an automatic one this morning when I returned the caravan to storage). All hitched and off we went. With the caravan on hook, the car automatically disables pilot assist, Blind spot warning and the rear fog light, but does let you use the adaptive cruise control - very handy for following lorries.
With all the torque on tap, and AWD, pulling away and getting up to speed is very easy, and the weight of the car keeps the caravan under control. The adaptive dampers manage the extra weight with no problem.
Having left home at 10:30, we pulled into the Instavolt Winchester hub at 12:11, 82 miles later, at 18% battery. Winchester has 4 pull through charging stations designed specifically for towing, so by 12:13 the charge had started. We both used the facilities, and I grabbed a coffee. 30 mins later, having added 70kWh of energy (an amazing average rate of 140kW - MUCH faster than the previous car), I stopped the charge and we got going again, having increased charge level to 82%.
The remaining journey of 37miles taking us down to 62%.
Over all the journey of 115 miles used 73% of the battery or 70ish kWh of energy, for an average of 60.93 kWh per 100 miles or 1.6 miles per kWh givving a theoretical maximum range of 157 miles.
We pitched and had a great week. Danebury is a lovely CL with individual water as well as metered 16A hookup (10kWh included per night). It also has the possibility of using their 7kW car charger, though we opted not to.
Having spent a great few days, the threat of the winds arriving tonight, and the potential for a very wet day led us to come home two nights early. We had been out and about during the day, and had the car charged to 83% ready to come home. After a quick pack down, we got underway just before 5pm. This time the battery was warm (it had been 18C all day, and we had charged on a 30kW charger in Lyndhurst), and the roads were bone dry, so I was expecting much better performance. Once out of the of the forest, and back onto the M27, I set the cruise to 55mph, until a lorry passed us, when I set it to 60, and let the car follow the truck at a safe distance. While stopping again was an option, looking at the economy readout, I was confident we could get home without a stop, a journey that would not have been possible on that starting state of charge in the Polestar 2. As we carried on, the economy kept improving, until as we pulled home at 21%, the car was reading an average consumption of just 52.9 kWh / 100 miles or 1.89miles per kWh, giving a potential maximum of 181 miles towing range, an amazing performance with very good results.
The combination of very rapid sustained charging (140kWh average up to 82%) and a real range of well in excess of 150 miles with a buffer in all weathers, makes this quite a machine. It allows for 300 mile days, with just one stop of 45 mins or so, if the bladders of the driver and passenger can manage, or 400 miles with two shorter stops - far more than I would normally consider in one day myself. Perhaps the south of France with the caravan is on the cards for next year :)
3,500
Good to hear of the existence of pull-through charging bays - they need to be encouarged to spread quickly around the country.
Reactions: Tobes
9,006
Thank you for the report, amazing how the car’s performance has improved over successive generations. 300 miles with one stop would be more than enough if I was towing. Even solo I stop around every two hours not necessarily for bladder, but don’t want another DVT.
Reactions: Tobes
Feb 23, 2018
919
88
18,935
Other than a quick sit in a Polestar 2 in a Shopping Centre "boutique", I'm yet to drive a full EV. Everything I see says they make great towcars, due to their power delivery and higher weight. However, the charging infrastructure at motorway service areas doesn't seem geared toward the EV Caravanner yet.
Recently I mentioned being at Telford services and seeing a caravan abandoned in the coach park to allow the owner to reach the charging bays in the twisty carpark. This services has the standard 2 charger points installed many years ago, but Welcome Break added a rank of Tesla chargers and are now installing more 3rd Party chargers. But they are on a raised area, so even more out of the way of the caravan area.
I'm sure when EVs start to equal ICE vehicles things will change.
Reactions: Tobes
Jul 23, 2021
1,041
988
5,435
Interestingly, MSAs (motorway service areas) are usually my last resort for charging, with or without the caravan. There are so many other options for places that have better facilities for EVs to park and charge without the hassle of one way systems and dedicated parking.
The infrastructure has improved vastly over the last 4 years, and is getting better every time we go out.
2,221
A excellent review Tobes. Our EV runabout is brilliant in every way. Perhaps we will take the plunge on an EV tow car at some point.
5,210
Great car and write up, but not so brilliant when you take into account that electric still comes from fossil fuel and last year tax payers paid over £1 billion for wind farms to be shut down adding to the cost of a kwh. Never mind that thousands of people have been put out of work adding to the benefits bill.
5,301
Excellent script Tobes. Thanks for all the details. Like you my son avoids MSAs like the plague!
People like Instavolt I understand are build new charging stations daily with easy drive in drive our access.Hopefully making life easier for the EV Caravanner
Your Polestar sounds an absolute powerful beast.
Does it have a more conventional, less distracting dash board display?
Is it true there is no rear windscreen, just a camera?
5,210
I find it quite annoying having to go into sub menus to switch off something like Lane assist/departure. The latter is my pet hate on new cars. Why can't they make simpler easily accessible menus or switches?
3,500
Most manufacturers have now seen the light and reverting to using buttons rather than rely on touchscreens - even Tesla are with the revised model 3
Feb 13, 2024
1,271
808
1,435
In so many ways EV's have already exceeded ICE vehicles especially in terms of fuel efficiency, lifetime reduction in releasing pollutants, fuel costs, and price parity or better as battery prices have fallen dramatically.
And there exceeding them in spontaneous combustion 💥
4,311
Yet again you make your deliberately misleading accusation that ignores the very substantial amount of power generation that comes from renewables. These days often more than 50% of our demand, is covered by renewables as Otherclive has frequently shown.
Obviously we do need to have alternatives to cover peak demands, but that is only needed on fewer occasions when for whatever reason renewables cannot meet demand.
The issue of cost and paying for standby generation is a political matter, and I agree the protocols do need to be revised, but there is no doubt that the use of renewables has reduced the power generators pollution, and is helping to preserve the finite resources of fossil fuels the planet has.
9,006
I cannot agree that electric comes (solely) from fossil fuel. Yes in part it does, but increasingly UK is getting the majority of its electric from renewables. Today it’s 77% probably with some northern wind farms at reduced output due to Storm Amy. There were periods in September where UK were 95% renewables. So given future investment in inter connectors from Scotland and grid up dates etc and HP2 coming on line, the reliance on fossil fuels will further reduce. WRT contractual pricing where companies get money for shutting down wind farms, or gas stations get high rates for spot generation the government and regulatory bodies have to tackle that particular inherited issue.
Given that the energy sector is crying out for staff vacancies that cannot be filled, I can’t agree that thousands have been put out of work is entirely accurate. Yes jobs have been lost, but new jobs are available and it’s no different to any period of technological change. Even the warship ship building industry is short of welders, electricians and pipework trades due to record domestic and export order books. Just think how many grooms, farriers, harness makers, etc were put out of work by the introduction of ICE. 😂
5,210
Please point out where I made a deliberate misleading accusation. It is you that is making wild misleading accusations attacking me once again so wind in your neck.
Can I suggest that you read on the money wasted last year paying wind farms to shut down before making any further comments? This is cost all of us huge amounts of money and we have one of the most expensive electric tariffs in the whole of the EU and probably the world! This leads to poverty and people suffering or does that not matter to net zero zealots?
9,006
For a lot of modern cars the rear screen is neigh on useless for decent manoeuvring visibility and having a camera for rear vision is no different to fitting one to a caravan.
9,006
Mine switches off lane departure warning from a press switch on the steering wheel, but wonder if later versions of Toyotas don’t allow that. Anyway I tend to leave it activated as it doesn’t intrude other than an occasional triple buzz.
5,210
You are correct, but cheap electric still comes from fossil fuel and very expensive electric from renewables. Why do they have to pay over £1 billion for wind farms to be shut down and the then at other times pay millions for old power stations to be fired up as no wind or sun? It is the consumer paying the cost.
Those staff vacancies are probably for clerical staff mainly at suppliers and not distribution companies. Unlikely someone working on an oil rig will have the skills to deal with electrical supplies and there ae thousands out of work because of the lay offs. Remember it affects the suppliers, the retail sector etc. The net zero goal set by a certain MP is destroying thsi country and there is no way getting around that pig headed person.
5,210
Living down country lanes it is a hazard and not help.
9,006
I think you may be ignoring the fact that the gas fired generation stations are also paid extremely high rates when wind/solar have insufficient output, plus there are no longer any “ old power stations” to fire up other than DRAX on its dubious wood chip boilers !
The vacancies in the energy sector are real technical vacancies required to design, plan, install and maintain infrastructure. Likewise in a number of areas the UK has a shortage of certain categories of skilled worker that is delaying works and growth.
Many don’t realise that the cost of electric is largely pinned to the cost of gas, which is pinned to oil costs. So divorcing renewable electric from gas derived electric is the major challenge
in reducing bills for UK domestic and business users.
2,569
I am in agreement with you on lane assist but my other hate on my car, driver fatique it comes on after ten mins on road
