We had our water freeze overnight thursday in our caravan. Well it was -13 C. The waste water had froze in the pipes too. So I filled the kitchen sink with hot water which normally within 10 mins clears the blockage. This time it didn't so I thought I'd use a plunger to help it. What happened was the sink drain came apart depositing 5 litres of water all over the cutlery draws.
Why did it happen?
The manufacturer of the drain had push fitted two plastic parts together without any glue! I wouldn't of minded if it was a cheap fitting but as we all know by the time the products get to the stand in the caravan shop they're already 400% dearer than at the production line. But for the sake of a dab of glue the £4-99 plastic fitting is now not fit for purpose.
Now given the volume of caravan production and the amount of drain wastes bought as aftermarket spares, there is no real case to justify scrimping on the cost of a litre of glue. Thats about what would be consumed in a years production.
I would love to show the cost cutter an inside view of my sink to explain why penny pinching doesn't pay!!!!!
Not so long ago things were "engineered to last" now it's "designed for failure". Yes having been in research & developement, I can assure you a designed life expectancy is now included so that the manufacturer has a pre-determined spare parts production criteria to meet and guarantee'd repeat custom.
Grrrrrrrrrrrrrrrrr
Why did it happen?
Grrrrrrrrrrrrrrrrr
