Porch awning Adria Altea Severn
Mar 7, 2017
12
Hi - we received a Vango Rapide 350 with our van as part of the starter pack - but can't seem to make it fit well? It interferes with windows at both ends and side locker - or just the rear window if set back. Oddly it seems the width (inside) is 290/300 not 350 - and 350 probably would clear the door to window?
We're gonna fiddle some more (and chat to the dealer as we presume an included accessory should fit) - but wondered if anyone had succeeded with this awning - and how if so, or any recommendations for a porch air awning to fit this van?
Cheers very much
4,759
Sadly both our porch awnings, Isabella and Kampa, either partly cover a windows or block a locker.If we leave the windows clear then the door is half blocked! !
This is one of those things you have to live with I am sorry to say.
Feb 3, 2008
3,790
We are lucky as our porch awning doesn't interfere with any locker, door or window. Last time out I even managed to move it rearwards by about a foot and insert the rear edge into the vertical awning rail.
Here is the awning before moving it rearwards:
Only door and front window on this side of the van, with locker under front window:
Aug 23, 2009
3,167
I'm lucky too both the Issy Magnum and the porch fit perfectly. We did however measure up carefully before buying the new van. We wouldn't have changed to the new one if the Magnum hadn't fitted.
Mar 7, 2017
12
Cheers for the replies. The best solution we've found so far is to set it up further back - but that still nearly splits the rear side window in half. OH not happy. Have contacted dealer to see what their thoughts are.
I can see different perspectives - yes 'it fits' - and this happens - so put up with it. But as it can't be fitted against the wall, would you match the awning with this unit if given the choice - no. As I believe there are porch awnings that will fit around the windows - it seems it would have made sense for the dealer to have supplied one of those in the first place?
We're also slightly annoyed to discover that the stated awning width is actually only the floor width - so any attempts we made to see where the awning might fit against the caravan wall before we purchased it were meaningless
513
When we changed our caravan we had our porch awning altered so that it did not cover windows on our new van, there are several companies that advertise in the club magazines and PC, they will collect and return by carrier, may solve your problem if the dealer is unable or unwilling to help.
Apr 20, 2009
5,611
1,012
Think your Altea is very similar to mine although mine is badged as a Fleetwood.
See if a 390 will fit, if so ask dealer to swop.
The 390 fits between the front window and door, covers the kitchen window and leaves the rear window free, and it doesnt block any lockers either.
Take a tape measure and check it.
Mar 7, 2017
12
Cheers for that Gagakev. I've had a quick measure and it does look like 390 is more the ticket - I will have a longer look to make sure there is enough vertical height before the back corner curves away later on. Currently considering options between 360 and 400 - given that we've learned that the 'number' can just refer to floor width and not actually resemble wall to wall width. OH is also wondering whether to just go for it and get a full awning?
Apr 20, 2009
5,611
1,012
Had a quick peak at your specs and seems my van is half a meter longer so double check the 390/400
As for a full awning I bought one last year second hand, as new Dorema good quality bit of kit but then it was on a seasonal, wouldn't fancy setting it up on a regular basis. we find the 390 has ample space even for the longer breaks we are able to take. The 390 is a Kampa (not Air) had it 6 years and although looking tattty will go again for this year.
Mar 7, 2017
12
Cheers again Gagakev. I'm defo checking as I'm not sure there's the full height length for a 390+ - but then that all depends on how the manufacturer measures it. If it's the floor - with a different vertical width - that's a different ball game. Bw
Jun 17, 2011
56
18,585
You have to measure the distance from between the side windows to the other side of the door and buy a porch awning that size or as near as you can get.
there is no other way.
Mar 7, 2017
12
Thanks again for all of the replies. So far, dealer isn't interested :(
Basically - he says that this type of 'universal porch awning' is designed to fit all caravans depending on the length of the flat section of awning rail - and that the actual positioning is down to personal choice which may mean it goes over a window, locker door etc but that the "foam pads" are designed to do this.
I've told him that our personal choice was/is that it doesn't actually go over the window - and that we had measured the awning out in front of his staff accordingly (who didn't correct us that 350 isn't actually the width of the awning at window height - just along the floor) - and we are now stuck with a situation that it does.
He suggested we buy a full size awning - which we didn't originally want for various reasons - and I can see is quite an expense!
1,961
Hi. I am no expert on the Consumer Rights Act here, but if you bought the van with the awning as part of the contract, and it is not fit for purpose, ( which might be the tricky bit) then you might have recourse. Prof John, Sir DD and others are all over the CRA. They will know if it applies or if I am just talking rubbish ( won't be the first time, B) )
12
Cheers Mel,
I'm fairly certain that the not fit for purpose bit would be tricky - as they can argue that it is - and that it is common for porch awnings to sit over windows etc. (as supported by various comments). I think if we had explicitly specified that it must fit in a particular way - we would have a case - but the communication was looser than that - and in our inexperience / naivety - largely based on the assumption that the supplied awning would fit without covering the window, lockers etc.
The flip side of this is that our measuring up in front of the staff clearly indicated an expectation / understanding that the awning fitted either side of the windows, and from previous experience, I wonder if they had a responsibility to advise us when we were clearly misguided?
I'd welcome any other thoughts.
Aug 23, 2009
3,167
You certainly find out the good dealers from the chaff when something isn't as you expected. Yes many people do have the awning over the window or an unused outer locker but there are probably even more of us out there that would never risk scratching our windows with a flapping awning end.
When we bought our current van we checked the length between window and locker very carefully as we did not under any circumstances want to change our porch awning. It's the best we've ever had for ease of erection and we explained to the dealer it would be a deal breaker.
Will the dealer not just take the awning back as it's unused and let you chose something that will fit? Failing that just sell it and replace.
Mar 7, 2017
12
Sadly the awning is used - we only discovered this during first use on site. I'd had a look at the awning at home - but we couldn't put it up as we'd had to move the van because of works right outside the house.
It feels like the dealer has washed his hands of this. No response to last comms. It's a shame - we had some snags which are ongoing - and these things happen. But this is something that was definitely in his control - it didn't go well - and this is his response. And we've got to conclude dealings with the snags. Bah!
I think in time we'll have to sell and replace - not an easy thought when you've just scraped thousands together to get the van in the first place.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
frfrg
