Porch Awning to Half Awning
Feb 3, 2008
3,790
Our Bradcot porch awning has beading down both vertical sides. As we use it near the rear, as per picture, I've shortened the rear vertical beading by a couple of inches such that the vertical beading can follow the horizontal beading into the awning rail. Theoretically the porch awning can then be used as a half full awning and eliminate draft from one side. The first trial insertion will be next month, but has anyone else done the same?
533
Hi WC
We have used a full awning as a porch by breaking the bead at both sides and using 2 corner poles that accept the bead, with a pad attached you get a snug fit at either side, if any one is thinking of doing same, you measure floor to awning rail at each side and then add the length of awning rail you want to cover, the 3 figures added together give you the size of awning needed. Useful if you need to avoid covering a window.
Mar 2, 2010
1,231
6
19,185
and us
[img size=400 x 400]http://i280.photobucket.com/albums/kk161/daveclarke1950/RosieRivendale3_zps90f5a1af.jpg[/img]
Converted an Isabella into a combi
