I am an adult sleep apnea sufferer and have to use a CPAP or constant pressure air pump, at night to sleep safely. I am having to change to an automatic pump which does not have 12 volt back up facilities.
I need a contingency plan for power failure.
I've thought of using a power inverter to power the pump should we loose mains electric on site. But what I really need to know is how big does the inverter have to be? My current pump according to the data on the base of it requires 1 amp at 240 volts ac, and 3 amps at 12 volts dc, to run it.
So assuming I need 8 hours of the pump running, can any of you electronics buffs recomend an inverter and also where I could obtain one.
Many thanks in advance for your advice.
Steve L.
Steve L.
