power management pms5 charger
Mar 28, 2005
8
could anyone help, my bessecarr charger keeps tripping the mcb every time I put the charger switch on.I `ve checked all the fuses I think I would be grateful for any help
3,587
Hello Ian, If and MCB is tripping then it indicates that a fault is still present. Generally MCB's react faster than fuses, so I am not surprised that the fuses appear to be OK.
If you are certain the charger is the only item that causes the MCB to trip then I this needs to be investigated. Many chargers are manufactured with their cases riveted closed and thus are not suitable for home repairs. Most modern charges employ switch mode power supplies, which are inherently more complicated than the older style simple transformer and rectifier circuits. I recommend you seek professional help through your caravan dealer.
Mar 28, 2005
8
Thanks John I was hoping there would be a simple fix... I suppose I will need to splash out , from what I see it will be rather costly
May 30, 2005
Hi Ian
How did yoy get on with this problem
I have exactly the same happen with my PMS4.
I guess it is a replacemnt system, which I imagine is quite expensive.
Would appreciate some info
Regards
Reg
Jun 1, 2005
Hi Ian
Regards
Reg
Hi,
Just for your info, I have just had to replace my PMS 4 unit because I used a generator on my van and that blew some components on the charging unit. Price was
