power to the rear of my 2004 peugeot 406 estate
Jul 10, 2007
the issue is trying to get a cable through the bulkhead - i can't seem to find a grommet to use as the only thing i can find - high up- is a small cable [6mm?] on the far left [looking into the engine bay] high up and just before the drivers side wing. Can someone tell me specifically, where there is a grommet/hole to get through the bulkhead.
it was my dad's car and he has just passed away - i need to treat this car with the ultimate respect and care - there is no way i can risk damaging it in any way by drilling a hole "blind" in case i hit something the other side or add an "open wound" for rust to get in
As a compromise, is there anywhere i can "tap" a 35/40amp supply inside the car [not that im going to pull that kind of current but it helps with voltage drop to find a heavier than needed supply.]I'm not usually a person to compromise but in this case [see last paragraph] I would rather bin the caravan than mark the car in any way.
Has anyone tried running a cable UNDER the car? are there enough places to cable tie to? [can always protect it in a piece of hosepipe]
it's a deisel so fire hazard not so great but i'm not thinking of running along the fuel line.
Help! holiday looming!!!!
Aug 25, 2006
758
Hi, Andy.
Start at the fusebox. At some point there WILL be a place where the loom has to pass through the bulkhead.
Alternately, take a feed (fused) from the fusebox which becomes live when the ignition is on, but I wouldn`t recommend this as it`s too easy to flatten the battery if you inadvertently leave the ignition on with the engine not running. If your feed is switched when the ignition warning light goes out (i.e. correctly) you wont have the worry of this.
I wouldn`t go with the `under-car` route, and it`s not necessary.
