I take issue with people who infer that car manufactures supply inadequate suspension systems for the loads stated in the car's specification.
Anyone who believes that the car manufacturers supply sub-standard suspension systems should take it up with the manufactures.
On the basis the car manufactures do supply adequate systems, there is no imperative need to alter what they supply. If there IS an imperative need to change suspension parts, then it means a part is defective, the car is over loaded or your expectations are unreasonable.
No change to any part of the suspension can legally increase the maximum loading capacity of a type approved vehicle.
If a manufacture includes SLS, spring assister, or variable rate shocks as an OEM option, then it will be taken into account in the type approval process when assessing loading. If any of those items is added after manufacture they cannot increase the loading capacity, as it was not part of the type approval process for the vehicle as supplied.
The use of such devices will change the characteristics of the vehicle and its handling. Whilst some additions may 'improve' a characteristic, that does not devalue the manufacture standard specifications.
