Lisky said:
Thanks for quick reply. Yes I own the caravan the heater I had in mind was the ridgeyard model 24kw output no electric used to power it as runs off batteries for ignition also found one that runs off 5.5 kw supply. I'm guessing with that and other restrictions you mentioned it's a no go. What I'm trying to achieve are longer showering times can you suggest anything? Maybe an electric shower as I don't have to worry about tripping anything on a campsite? Or maybe an onboard water heater with larger hot water storage capacity?
Hello Lisky,
From your questions and suggested equipment, I suspect you and idea of what you want but you have not worked out what you really need.
How many people do you want to accommodate?
How many showers per hour do you want? and how long will each shower last?
Having unlimited fresh water available is a great idea, but you must also make provision for the waste water.
A cold water tank in the caravan may become a liability in winter if no one is using the van and it freezes.
The ridgeyard model 24kw water heater you suggested is not approved for use in touring caravans as it has an "Open & Force Flue Exhaust Type" . In addition its heating capacity would require a massive gas take off from the gas bottles and would exceed the ratings for the standard regulator and the caravans internal gas pipework.
The caravans water pipes are only designed to work at a maximum pressure of about 20psi anything more and joints are likely to blow. With this pressure restriction and the size of the pipes the effective maximum flow rate will be about 1 gallon (9L) min. The caravans drains are not capable of handling more that that either. Running such a heater at such restricted flow rate it may not regulate the water temperature leading hot and very hot water being produced cyclically.
The idea of using an electric shower - most showers are rated at between 8 to 10kw, where as the caravan electrical wiring is only rated to a maximum of 16A or 3.6kW
To accommodate the scale of heating power you have identified, the caravan would have to be radically modified.
