purpleline Ko-Jack
Has anyone fitted the KO-Jack to a twin axle caravan,as I am thinking of buying one.They are designed for jacking and levelling up to a 2000Kg caravan. If these are used for levelling I would imagine one will need to jack the wheels higher than the level point to allow for the suspension to re-settle after the blocks are placed under the tyres.Any comments appreciated.
Regards Jim
Hi Joby
Do you put supports (ramps/timber)under the wheels?
I bought one a couple of days ago but not had time to test it.
Does the jack lift both wheels clear of the ground? As it's mounted to the rear of the twin axles, it looks a long way away from the front axle, if that makes sense.
PS I was thinking I was the only one who had one by the response from the forum members!!
Regards Jim
