Question for Martin (Whale Pumps)
Apr 20, 2007
71
Hi Martin, I have a Senetor Wyoming with an onboard tank and pump. It has the manual valves under the front seat, which is a pain. I would like to fit the electrical valves but they are so expensive ( in excess of £300 plus fitting ) I hope you don't think this is a cheek Martin but could I fit two central heating 3 port valves instead and would it work the same? I will understand if you don't reply to this question for business reasons. Thank you.
David(from Kent)
May 5, 2005
1,154
As far as I know all zone valves I have seen are 240volt so apart from the physical size and the reducers that you would need would complicate things more We have Series 6 with the valves moved to access through a drop down panel which doesnt seem difficult to do to make it easier.We had Series 5 Indiana and its one of the things I really like about this one.
Apr 20, 2007
71
I can understand your reluctance to answere my question Martin, but thanks for the reply. It is a shame you have to go through a dealer to purchase the system.
Regards David (from Kent)
