- Jun 22, 2019
- 3
- 0
- 0
Hi all
I'm new to owning vans and having just bought one privately I've found a few minor issues (it was a bit of a bargain so I was expecting to do some work to it). It's a compass coachbuild and I'm having issues with a tap.
The mixer tap for the kitchenette sink which was loose and once I'd filled her up with water and tested the water pump, it spewed water everywhere. After much head scratching and bad language, I managed to find access to the back of the tap and pipes. The tap is probably a reich and has 2 flexible pipes that were push fitted into 2 straight 12mm push fit connectors. As a stop gap, I stopped at a parts supplier in Ringwood and was given 2 red end plugs made by John Guest. Unfortunately, these didn't seem to work and still leaked.
My question is this. Are the minor differences between Reich and John Guest 12mm push fitting accessories?
I ask because the supplier ordered me a new mixer and I'm not sure of the brand except that it looked VERY similar to the one I am replacing. Is it possible that depending on the brand I may need to buy different straight push fit connectors? Even though they are all 12mm?
Advice would be much appreciated.
Michael
Michael
