Rear End Sockets, TV Points
Hi again,
was wondering how difficult it would be to install an extra 240v socket and also tv ariel input at the rear dining room on my Abbey Aventura.
I am competent enough when it comes to the wiring, but is there any easy way of routing the cables so that they are unseen ?, anyone done this themselves.
thanks in advance for any help and advice.
Sorry just re read your post
you will have to decide were you want it putting & how easy it will be try to follow other wire trunking if possible
good luck !
Usual way is to try and hide the wiring in bed-boxes,cupboards, etc where you can. If the wiring has to run up a wall or somewhere where it will be exposed, then you can use plastic electrical mini-trunking. This normally comes in white box-shaped lengths from the main D-I-Y outlets, but you can get D-shaped neater stuff which comes in various colours if you search it out. B&Q sell it - see www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9726454&fh_view_size=10&fh_start_index=10&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=mini-trunking&fh_eds=
