Rear locker won't open - Bailey
Jul 14, 2025
15
The rear locker on my Bailey Unicorn Cadiz won't open. The key unlocks it as usual, and the button can still be pressed, but it just won't open. Has anyone else had this problem and found a solution?
Many thanks
Jul 14, 2025
15
Thank you. I wasn't expecting that to work because the key did unlock it before, but it just wouldn't open when the button was pressed.
But it did work!
When I looked at the open locker I could see that it is a plastic hook that moves at the press of the button. I'm going to give that and the edges of the locker door a thorough clean to see if that helps prevent further problems.
I read elsewhere that the very hot weather may also have been a contributing factor, making the door expand slightly.
Again, many thanks
8,528
Glad it worked for you. Add it to the "bucket of hard won experiences" (y)
Periodically I would go around all of the locks and give a quick squirt of GT 85.
Reactions: Blacksmith
Oct 8, 2006
2,000
692
If you can afford an aerosol of it, white Lithium grease is extremely effective and doesn't melt or wash off.
It is also good on the handle mechanism of multi-point patio/conservatory/porch doors if they loose their ability to spring back to the rest position.
400ml is a tenner though!
8,528
Surely not to use a grease to lubricate the lock, it would attract dirt.
Reactions: borderbilly
Feb 13, 2024
1,050
662
1,435
No, No, No dont use grease, get some graphite lock powder and you wont have much trouble with it.
