Reich remote control
May 5, 2005
1,154
Has anybody got the instructions to reprogram the remote control to the Reich motor mover,we are in France and the battery to remote went flat,fitted new one but its lost its code.Have got it working using the wire but its tricky checking I,m not goung to hit anything.Mods have my email address or an instruction on here would be great.
Thanks a lot
Feb 15, 2009
300
HI! deli Dave hope hols going ok. right my mover is model NoART-No 527-0521 Single axle REICH ( synchronisation) .Turn off remote,turn on isolation switch.press reset switch inside gray box under front seat (AND HOLD IN).turn on handset (double click).red light should be on .turn of handset red light off )release reset button ALL THIS MUST BE DONE WITHOUT PAUSES OF MORE THAN 2 SECOND BETWEEN PRESSES. (synch complete) RESET the reset process is only required if the LED inside the gray box shines ( RED LED light inside gray box should be lit if there is a fault) turn on handset (double click) press reset button (RED led inside gray box should be off).turn off handset ( reset process completed) Caution if the LEDdoes not go out after repeating reset procedure for several times contact your dealer. the LED inside the grey box should never be on unless there is a fault. hope this helps good luck .Anymore info get back in touch on (dougieanddenise@btinternet.com) cheers Duggie
hope you understand this
Mar 2, 2006
128
RESET PROCEEDURE
switch on the remote control with a double click on the I/O button. push the reset button at the electronic box once. the red led at the elec. box goes out.. switch off the remote control by pushing the I/O button once. another double click on the I/O button will make the reset complete.
SYNCHRONIZATION PROCEEDURE
if the remote control is switched on switch off now. push the reset button at the elec. box and keep it pushed down. at the same time double click the I/O button on the remote. the red led at the elec. box will flash. Then push the I/O button on the remote once and release the reset button at the elec. box .
Now the sync. is complete.
PLEASE NOTE THAT THE RESET AND THE SYNC. PROCEEDURE IS ONLY POSSIBLE WITH THE MAIN SWITCH ON AND A FULL 9 VOLT BATTERY IN THE REMOTE.
Hope this helps word for word from my instruction manual my mover is 5 years old enjoy your holiday and letus know how you get on.
Will S
May 5, 2005
1,154
Many thanks both,off to try it,having agreta time but you have to buy a wifi card and it only works near the bar area so have to have a beer as well
All the best Dave
Feb 15, 2009
300
All the best Dave
HI! Deli Dave did you get the mover working hope you did .All the best for the rest of the holls .remember the postcard ??!!!!
cheers Duggie
May 5, 2005
1,154
Hi Douglas,sadly it didnt work without the wire but at least I could use it plugged in,just got back today,have a spare remote off ebay will try tomorrow and see if that works,never had a problem before so hoping its something simple.Thanks a lot for your help
Dave
Feb 15, 2009
300
Dave
HI! Dave good you can still use your mover. is it not under gaurantee,let us know what the problem was/is hope you had a good holiday still got ours to come yet .
Cheers Duggie
