Reich Rollers
Mar 26, 2006
45
Hi
Can anyone advise me where to get replacement roller for Reich Motor Mover, or does anyone know of a website I could contact. Thanks for any help. I live in the Worksop area.
Jul 25, 2005
164
Geoff,
Two things you could try:
1 Order direct from Reich UK address:
Reich UK office (motor mover),
81-91 Hednesford Road,
Heath Hayes,
Cannock,
Staffs, WS12 3HL.
-OR-
email infouk@reich-web.com and ask for nearest stockist,or outlet.
web www1.reich-web.com
Hope this helps, Best of luck,
Pop
Mar 26, 2006
45
Hi Pop
Thank you very much for information on Reich rollers will try the addresses and let you know the outcome.
Jun 11, 2005
391
Hi, you could try R&L Draper who are Reich installation agents and who hold spare parts. Their web site is www.caravanmotormovers.co.uk
May 12, 2005
470
Geoff,
Contact reich uk by Email they will tell you who is your nearest dealer and you can order through them. I know this because I`ve just received and fitted my new rollers.
Have you heard about the new aluminium rollers ? they are fluted instead of having a gritted surface,and should last a long long time, they are the same price (nearly)as the old style steel ones, but weigh a hell of a lot less.
good luck letus know how you get on
Tony A.
Mar 9, 2006
265
Geoff,
Tony A.
Hi Tony - Are the rollers stright-forward to replace, or did you encounter any problems?
Eddie.
Mar 26, 2006
45
geoff,
If you only want one old style I have one that is ok, where do you live?
Tony A.
Thank you all for your advice re: motor mover rollers, I got in touch with the Reich uk website who were very helpful, and have managed to order from local stockist aluminium rollers. I hadn't heard of them before asking on the forum, also Tony A thank you for your advice and kind offer of spare roller. I am going to give it a go at fitting them myself.
May 12, 2005
470
Eddie sorry for deley I haven`t been into forum for a few days.
I removed the mover from the van and changed the rollers on the bench. Had I been of thinner build I may have been able to get under the van and do it, three bolts hold the motor in place, when these and the motor are removed the roller should pull out. I started by undoing the allen screw in the end of the roller, but found that this is uneccessary. just take the motors off, and you will be fine.
Good luck Tony A.
Mar 9, 2006
265
Good luck Tony A.
Thanks very much for that Tony. I see Reich are now doing aluminium rollers-they're on eBay at the moment-about
