- Nov 11, 2009
- 25,860
- 9,531
- 50,935
Your photo hasn’t displayed.Photo of another brand of seam sealer that can be used.
Oh dear cheers I'll try again 😊Your photo hasn’t displayed.
Welcome . From GaryPhoto of another brand of seam sealer that can be used.
Welcome . From Gary
It's a good idea to Take photographs before you start for reference.My 1992 Abbey used ph2(Philips head).replaced using stainless steel from tool station they are only available as PZ (pozidrive) which has no bearing on it's structural integrity 😊 (in case anyone is worried).I considered putting dampers on mine but unfortunately there is no provision to fit alko dampers on my year of manufacture.In MY personal experience I have found that if the caravan is aluminium and the awning rails are aluminium then a mastic sealer is used as per my picture,if however a caravan made from a plastic material and a plastic awning rail the a stikaflex sealer is used..As you will be aware aluminium expands a lot on the odd occasion the sun comes out and the bituminous sealer allows for this, plus it's easier to remove if and when needed.😊..GaryYeah I’m very conscious of this. For that reason I am essentially keeping the same except for making the bed bigger and storage smaller, but will keep the same structural features. In an ideal world I hope to not have to touch any of the shelving around the ceiling at all. I think if I can manage to leave that as is or directly replace it if required and replace and upgrade the corner structures (which were the bed and seating) I should be okay.
Weight is something I’ve only just began to read about here and see it popping up in all the renovation threads. This is something I’ll have to be very conscious of.
