replacement caravan carpets
2,516
Carpet shops - I'm not taking the mickey - they'll either make loose carpet to your size requirement or supply carpet, at whatever grade you want, for diy fitment.
Mar 9, 2008
247
Hi Christine ,
Carpets , it all depends if you want fitted carpets OR loose carpets to fit (and be removable ) your caravan . Any household carpet dealer will sell you fitted carpet for your caravan , then a good local carpet fitter will fit it , but you can probably fit it yourself . Its easy , just pull the old one out and you will see . Removable ones are different , will need the edges binding ( if they are not standard ) so look in the Yellow pages . Hope you find what you want , STEVE .
Mar 26, 2008
55
Many thanks to you both for your suggestions,much appreciated.I want to replace the removeable carpets in my van.The present colour is much to light to be practical.I know Allied Carpets do a binding service at a cost of
