Resealing awning extrusion.
Feb 1, 2012
33
I'm going to remove and then refix the aluminium extrusion on a friends aged Bailey caravan as it needs resealing.
Can anybody advise on a QUALITY gun application sealant? I'm not convinced that the sealant strip is any good. I would prefer to get messy with the mastic gun and make sure it's a once and for all time fix.
Dec 14, 2006
3,205
We use Sikaflex - and have resealed various places with it, without any subsequent problems.
937
The best adhesive to use is either Soudall Fixall, or Sikaflex 512, or Soudall RV61
Make sure you remove all the old sealant from the van and rail or you will be wasting your time
3,869
And make sure you secure the awning rail with new stainless steel screws one size bigger diameter than the originals but the same length.
Feb 1, 2012
33
Ta very much.
I'm a Sikflex fan. Great products, I've mainly used 221 and marine type. My wholesaler can get it in.
Stainless, always, size larger screw makes sense.
Just need to make some space in my garage so I can do it in the warm and dry
