Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Anyone have any plans or knowledge for fitting a micro wave as is factory fitted in a Pageant Bordeaux. Is it a DIY er job can you purchase the microwave from a Bailey supplier?
Ours sits on top of the unit containing the cutlery draw above the Carver heater. A shelf, with legs that fit either side of the microwave, then gives extra work surface at the same height as the gas rings on top of the oven.
I suggested removing the short cushion at the offside front and sliding the long mattress up to the window thus leaving room for a mirowave next to the unit you used
As they only use the rear bed it seemed a good compromise but met with no approval
They now have the Virginia which has shorter front seats than would have been the case above !!
Thanks everyone for your ideas. I thought as there are or appear to be micros in some of the Baileys I thought I could somehow fit one above the sink using the storage locker with the plug socket already in as they seem to be 'plumbed' in and secured with a strip across the bottom.
I would check with Bailey that the side/locker is strong enough - the later vans with the microwave fitted as standard may have extra strengthening to support the weight (about 12-14kg for a small oven)
