I had a RK Fuse control installed by our dealer at the start of the season and from the start it kept tripping despite being set up per the instructions. The dealer then fitted a new device and again the device trips.
We have just returned from a trip with the caravan and the following is a summary.
Pitch breaker was stated at 15amps so I set the Fuse Control to 12 amps. On several occasions the device tripped despite the calculated load being well under 12 amps. I re-set the device and later that day with minimum load being used, the pitch breaker as well as the main caravan breaker tripped. This type of situation was quite common during our trip away. I will be removing the device shorlty, however I am wondering if anyone else out there has had this type of fuse control fitted and if so have they had similar faults.
The devise is manufactured by:
REICH GmbH, Germany.
Russell Millar
Russell Millar
