Rotten floor
Dec 19, 2023
Hi, we bought an 2000 Abi Adventurer, we knew it had damp in the walls which we're confident we can fix. However, we did not know that the floor at the back end was rotten in areas, and we are at a loss for how to repair. In the very corners in a small patch, it is right through to the base of the caravan, then a wider area of approx 10x14cm in the upper layers is rotten.
We have taken out all the rotten wall panels and insulation. The caravan is under a cover and we'll be finding the leak/weak points and sealing.
I see a wizard caravan damp repairs site has been recommended historically, but this site no longer seems to exist.
Any advice would be very gratefully received.
1,793
There are several videos on you tube and if you use google you can find details of the things needed. It is not something I have done though.
