royal awning poles
Apr 10, 2008
41
Does anyone know a good tel number or address for Royal Caravan awnings. Some of our spring loaded poles on a 18mth old awning have failed. Desperatley trying to get them replaced, as can't use awning
Feb 15, 2009
300
HI Denise is there no address or phone number on the awning pole bag .OR there are brackets you can buy that fit over your defective poles and hav a wingnut that you can tighten to hold the poles .only problem is you have to drill small hole for wingnut/bolt to tighten against each other. OR try the internet just key in the name of your awning into a search engine ,try google
cheers Duggie
Apr 7, 2008
4,909
Hi Denise
Can you take a photo of what has broken and post it on here, I'm sure other people will have had problems over the years with spring loaded poles,
And then the suggestion's will come in as to how they have fixed there own
How To Post Photos ( ten easy steps )
hi denise search for love caravans on e bay . if you can supply her a pic or give exact diameter / length of poles i,m sure she will sort you out and if you in midlands area you could call round cheers john
Jun 11, 2012
1,525
28
19,685
Denise if you check out Pyramid I think youll find them in there as Im sure they are the same company based somewhere near Chesterfield I THINK.
Regards Sir Roger
